Tips for Mounting Rear Diffuser
    *I apologize for the pictures but I will try to get some of the inside to show you the missing tab locks.
    I recently bought a new carbon fiber rear diffuser since the clear coat on the one that came with the car was peeling and flaking. When removing the old diffuser, I realized the the corner pieces on the bumper side where the tabs of the rear diffuser to lock into had been broken by a previous owner. The old diffuser had been mounted using some sort of adhesive or putty type of goop. Now when I install the new diffuser, the two top corners pop out. And since I pulled off the old one with all of the goop, there is no way of remounting that one for the same reason. I plan on buying a new rear bumper cover at some point but would really like to drive my car until then with out it looking like crap.
    Any suggestions or tips on how I can mount the new diffuser until I get a new bumper cover? Thanks.
    You could get some of these:
    4 Way Adhesive Cable Tie Mounts bundles and secures wires and cables with a strong, dependable hold. Available in a range of sizes. Free returns. Order today.
    ...which are readily available at the big box hardware stores. Put them on the inside of the diffuser. Then take zip ties and attach the zip ties to whatever you can find that will hold, snug up it, done.
    Option 1: They are adhesive backed, which may or may not hold. You could try it with just the adhesive first - clean the inside with isopropyl alcohol really well.
    Option 2: If that doesn't hold, you could remove the adhesive backing and use some plastic and & FRP type epoxy to glue it in place. This option is a bit of a pain in the ass for sure, others may have some better ideas.
      I appreciate the idea. I will probably give it a shot. I hope it can stick without having to glue it.
