Suspension refresh - critique my life choices
    Long post warning!
    Hey everyone, I’m getting ready to start a long overdue refresh and upgrade on my car. I have been thinking and overthinking this for a while, to the point where my brain is kind of at max capacity LOL so I would like to get your opinions and feedback on the stuff I’ve selected. Also, it would be great to get a dummy check and help me make sure I’m not missing anything before I jump in.
    Goal: 80% track 20% street as a ballpark. More track leaning is fine. I have owned the car since 2018 and I am fully ready to have this not be a regular street car anymore. It’s not special or clean so I’m not “ruining” anything.
    Car: 2001 M3 coupe, already has VANOS, bearings and RACP plates done
    Workshop: Home garage with quick jacks, 2 floor jacks, various jack stands, plenty of tools but I’m sure there are special tools I will need
    Wrenching experience: high intermediate
    Basic outline of project:
    RACP: Car has existing plates from previous owner, I’m going to leave well enough alone and I have a Yurkan Cages rear 6-point brace to address top side reinforcement
    Suspension: KW Clubsport coilovers, off the shelf. Hotchkis sway bars, Rogue Engineering front strut tower brace. As I type this I realize I need to confirm that I have the correct end links for this setup
    Front axle: Motorsport hardware wheel studs
    Wheel bearings were done a couple years ago and roughly 20k miles, going to leave those for now.
    Bimmerworld TrackCAB control arm bushings
    Lemforder tie rod ends
    OEM control arms
    Leaving the steering rack and all of that stuff alone for now
    Rear axle: CMP monoball RTAB
    SPL race rear adjustable LCA
    OEM outer control arm bearings, upper
    OEM outer control arm bearings, lower
    Anything missing on the front or rear axle? What about the rear upper control arms themselves, are these typically fine to replace bearings and reuse, or do we consider them a wear item?
    Subframe and Diff: CMP solid subframe bushings
    CMP solid diff bushings
    Going to leave the actual diff alone for now. Also leaving rear axles and wheel bearings alone for now.
    The car currently has poly diff bushings in it, has high amounts of NVH but I am used to it and don’t mind it (call me crazy if you want)
    I was planning on dropping the entire rear end as a whole and doing all the cleanup and basic reassembly on my workbench. OR, I might honestly bring the whole rear end to a shop and have them do the teardown and reassembly off the car for me. I do not have a tool or experience doing all these bushings/bearings. What do I need to rent or buy tool wise if I decide to DIY? And what so I need to know as far as pre-loading things and reinstalling everything? Can we talk about the correct method and amount of preload to use to avoid issues with bushings?
    Drive shaft: may replace center bearing and guibo. How do we feel about Rein and Meyle HD vs original BMW?
    Brakes: DB9 front and 996 rear calipers, HEL lines, PFC fluid, OEM rotors, I haven’t bought the pads yet but I’m leaning towards trying the Hawk DTC-60s and using FCP for the warranty since I’m unsure if I will love the setup or not. I additionally have stock calipers and PFC 08 pads as a fallback. Edit: looks like the D1001 DTC-60 pads are backordered with no ETA, s oI guess I'll probably just get PFC 08 pads, Zeckhausen has both shapes I need.
    ABS/master cylinder/booster: I am leaving the stock MK20 ABS system alone for now, that whole rabbit hole is just a bit too much for me at the moment but I feel like that may be on the table within the next year or something like that.
    Wheels and tires: Volk ZE40 18x10 ET25, they have 275 NT01s on them now which have probably 3 or 4 track days left in them. After those are done I will either go with another set of NT01s, or something like the A052 or another similar tire. Do I need to roll or trim the front or rear fenders? I have 19” ACS Type III wheels and PS4s as well which I will keep as my street setup. I have some spacers to clear the brakes. I *believe* the ZE40s will clear the brakes and the KWs without spacers. I plan on running about -3.5 degrees of camber in the front and I guess -2.5 or so in the rear. I would like your guys input on baseline alignment settings though as I only have experience track aligning my E36 and Hondas.
    Also I plan on doing a cooling system refresh, as I’m unsure of the age of everything. I want to go OEM/OE/whatever is the preference de jour as I know the suppliers change. Advice on what can be aftermarket to save on cost vs. what needs to be original BMW would be appreciated.
    Lastly, please let me know if there are any must replace items and hardware that I’m missing. I'm getting new exhaust hardware for between sections 1 and 2, hoping I can drop section 2 and 3 together without taking them apart.
    Thanks for reading, looking forward to hearing feedback and critiques on these choices. The biggest things I’m unsure about are dropping the rear end, and how to properly reinstall the bushings and preload things correctly. I’m really excited to get gong on this project, I have a decent workspace and I don’t have to rush things.
    PS: Unrelated to the suspension, I’m also doing the following to the car:
    Bayside Fabrication bolt in roll bar, Racetech 4100WT seats, VAC seat mounting setup, Lifeline 6-point harnesses, AJ Hartman sunroof delete, reupholstered euro slitktop headliner, MK Rennsporttechnik GT4 lip, rear wing and dive planes, CSL style rear diffuser, and Motorsport 24 CF hood
    '01 M3, Imola/black
    Can't speak for the track parts, but for the cooling system I went for the genuine BMW hoses and water pump. These cooling systems don't have the e36/e39 weaknesses. I don't think there's a Stewart pump available either.
    I believe the driveshaft flex disc is originally made by Febi-Bilstein, and that one can be had at a significant discount. I can't remember if it actually did, but the comments on FCP claim it's one of those parts with the BMW logo ground off.
      Yeah stick to the genuine BMW water pump. Aftermarket meral impeller one failed after a couple years on my car
      The rein CSB I recently installed said BMW on it, so I'd go for that one. Can't remember who makes the OE guibo, but pretty sure it's whatever FCP says it is.
        Some comments from me:
        While the YURKan brace is probably absolutely fine to address the topside reinforcement, I would still inspect the underside and inside for damage.
        My car was plated prior to my ownership, but had severe damage in pretty much every area where failure is known, popped spot welds all over the place, from memory around 15 of them.
        I would suggest reading up on this article made by CMP
        That is correct. As we mentioned in the previous article, fatigue related failure is not limited to just the rear subframe mounts. This issue is so much more complex that it expands not just beyond the subframe mounts but, into sections of the unibody structure beyond the Rear Axle Carrier Panel (RACP)! In our previous
        and inspecting all area's mentioned, and performing a repair if necessary.
        Sounds good, but keep in mind that the SPL camber arms use an open spherical joint.
        Even though these arms sit in a cavity in the subframe, which would most definitely help against foreign debris entering the joint, they aren't exactly funny to replace, so I would go with either a sealed ball joint, or for example the ones from CMP which come with an optional boot to project the joint.
        The rear upper control arm can suffer from cracking (mostly due to running coil overs with high spring rates), and can also suffer from heavy aluminium corrosion around where the spring pad is supposed to sit.
        Inspect and replace only if necessary.
        If you have poly diff bushings already, as you stated, I would honestly just save your money and not purchase the CMP solid diff bushings, they won't improve your lap times, they will just cause more noise.
        With the setup you mentioned, preload isn't required on anything except for the inner bushing for the rear upper control arm.
        It isn't really preload, but sort of the opposite, avoiding having any preload at normal ride height.
        You can achieve this by torquing the bolt for the rear upper control arm inner bushing at ride height, either by measuring or by putting the spring in and jacking the control arm up.
        The need for this could also be entirely avoided if you changed that rubber bushing for poly or a spherical joint, I normally don't recommend this but as this is a track car that seems to be a fine option.
        Genuine BMW, Meyle sucks.
        Genuine BMW for all hoses and water pump.
        Thermostat is made by Borg Warner / Wahler, can buy that after market if it saves you money, exactly the same thing.
        Radiator made by Modine (NRF now), same thing as from the dealer.
          Agree with all of the above except the water hoses. I used rein with the Viton O-rings.
          The hoses seemed identical to OE, but did not say BMW anywhere in them.
            Regarding the giubo/flexdisk - FYI - buy the "Febi/bilstein" part, and in the red box will be a Genuine BMW (SKG) part. Rein (which, admitted, is not the highest quality) CSB seems to be fine for many of us who have replaced that part.
              FYI, Rein CSB I bought had the BMW logo on it. I’ve heard sometimes it says BMW and sometimes it does not.
              ordering from AutohausAZ had the BMW logo. Just purchased last week
                +1 on the Viton O-rings ( I bought mine on eBay and they came with the snyth lube, https://www.ebay.com/itm/295468391970 ), regardless if you go with OEM or aftermarket water hoses.
                  One you install a roll bar - the car shouldn't be driven on the street. More so for a bolt-in.
                    I did the same thing with the hoses. Threeish years + good amount of track time and they're still fine.
                      On the rear subframe: it’s going to be the little things that give you grief:
                      1) Wiring: the ABS wheel speed sensor and brake pad wear sensor. The plastic connector on the car side will crumble in your hands. Plan on replacing all three connectors with BMW ABS Wheel Speed Sensor Connector (2 Pin) - Genuine BMW 61131392246, they are $8.09 each. You will need small picks to remove the terminals. On the passenger side, paint or mark one so you can remember which is which.
                      2) Wiring: the cable clips that hold those wires to the rear trailing arm will break or have already. Get 10 or so because zip ties won’t be on par with everything else you’re doing. BMW Cable Clip - Genuine BMW 34521164653. They are $1.09 each.
                      ​Good Luck!
                      PS: new OEM bushings on the diff are my vote. Solid on the subframe is fine.
                        Awesome, thank you guys! I'm going to piece together my own cooling system and cross shop. I think I have the info I need re the center bearing and guibo as well.
                        Some comments from me: While the YURKan brace is probably absolutely fine to address the topside reinforcement, I would still inspect the underside and inside for damage.
                        https://cmpautoengineering.com/pages...ubframe-mounts
                        Thank you, the plan is to basically stop and reevaluate if I find anything wrong under there. I have the trunk gutted and I do not see any popped welds on the top area, I'm going to do as thorough an inspection as I can short of removing the sealant and plates that are already on the car.
                        good point on the bearings, I didn't think about that. I will probably still run these SPL arms though, everything I've listed I have already bought. I might reconsider the diff mounts.
                        For the rear upper arm inner bushing, I was under the impression that it isn't advisable to do a spherical joint because tha tcan limit movement which can in turn negatively impact how the rear sway bar moves since it's attached to the arm. Is that incorrect?
                        '01 M3, Imola/black
                          I knew this would come up, maybe you can elaborate on your stance for posterity's sake.
                          I realize the flaw in the argument of "I know lots of people who have roll bars and have never had a problem in an accident" so I won't go there. Nor would I bring up factory crash tested cars with factory roll bars. I would just say my best data point is the legality of cars like ours with roll bars like these in Europe, namely Germany, where TÜV is satisfied. TÜV is not without its flaws, like any government agency, but they don't typically allow things that are flagrantly dangerous to the occupants.
                          '01 M3, Imola/black
                            ​Good Luck!
                            Good call on the clips!
                            '01 M3, Imola/black
                              I know that the RACP is an issue, especially for tracked cars. But reading through these just remind me of why this chasis scares me. I'm just going to keep enjoying the car though haha.
