Originally posted by EthanolTurbo
Two years of intermittent hard starts, please help!
Thanks Terra.
My only experience is on the ms43 EWS. On that one we just jumped two of the heavy gauge wires together and disabled ews in the ECU. Been rock solid for months now.
I suspected the M3 EWS was more complicated but didn’t find any good wiring diagrams.
Any refs you can share?
Originally posted by ATB88 View Post81k mile car, have had it since 45k miles. For the first year it had always fired up beautifully with no hesitation or stumble. Two cranks then on, to a rock steady idle, every time.
"two cranks then on (engine fired up?) as you expect for a normal engine before you experienced with hard start? Why two cranks is normal?
In the first video, what are those two chirping noises at 0:03 , 0:04 timer, 0:26, 0:36, and 0:37 timer? Are these moments your starting problem that the engine didn't crank?
At 1:31 to 1:32, it seems the engine fired up but the starter gear was not released from the flywheel. Did you release the key too late?
I'm not sure that your concern is about those chirps or the issue at 1:31 to 1:32. If the issue is at 1:31 then I to test by pushing and jump clutch in 2nd or 3rd gear.
If the EWS is bypassed and the connector pin1 and pin2 jumped together, sure it works as you said but the ignition switch will die soon. The EWS internal "relay" is to reduce the current load on the ignition contacts.
We put an inline fuse between the wires just to be safe. But if the two contacts are shorted by the relay during a normal start condition what is the harm of keeping them shorted?
I understand that normally you might want a relay in there for clutch switch or other safety conditions before allowing the starter to run. That’s the only reason I can see relay be necessary.
You’re usually right sapote so I’m probably missing something obvious.
Hi sapote ! Thanks for taking a look
In the second video, we have several struggling starts in a row, starting with the first: https://www.youtube.com/watch?v=ZRlEFfOa_r4
I must admit the starts in these videos (taken more than a year ago) don't seem as bad as it is now. It struggles harder now, and, again, occasionally, it just doesn't start at all. I think maybe I should try and get some more recent hard starts on film to give an idea of what things are looking/sounding like now. I'll try and do that over the next week or so.
Thanks for the insights!Last edited by ATB88; 09-14-2021, 09:37 AM.
Originally posted by ATB88 View PostI HAVE NOW BEEN CHASING THIS PROBLEM FOR NEARLY TWO WHOLE YEARS :'<
Here's a current theory (a total reach, but a theory nonetheless): this all started after I did some VANOS/re-timing work (and yes, VANOS pass test with flying colours). Could be a coincidence, could be related. One possibility: I somehow manhandled the cam impulse sending wheel (at the back of the cam that give magnetic signals to the cam sensors) and warped a finger or something, and when that finger is in a certain position at startup it causes weird behaviour? Again, a total reach, but seriously, what else could it be at this point??2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
I don't see how you pass a VANOS test with flying colors with a stock CSL software (and CSL cam offsets) but with factory cams. Have you ever had it tuned before? Why don't you reach out to PCS Tuning, explain your hardware setup and let him set you up with a tune (no dyno, even). You'll be amazed. Start there, and then evaluate the cold start. If needed, he can modify the cold start table.'05 M3 Convertible 6MT, CB/Cinnamon, CSL Airbox&Flap, PCSTuning, Beisan, Schrick 288/280, SS V1's & 2.5" System, RE Stg 1&SMF, KW V2, CB PS, Apex EC-7R
Are you imagining damaging the impulse wheel or do you think you actually did?
Originally posted by jbfrancis3 View PostI don't see how you pass a VANOS test with flying colors with a stock CSL software (and CSL cam offsets) but with factory cams. Have you ever had it tuned before? Why don't you reach out to PCS Tuning, explain your hardware setup and let him set you up with a tune (no dyno, even). You'll be amazed. Start there, and then evaluate the cold start. If needed, he can modify the cold start table.Last edited by ATB88; 09-20-2021, 07:41 PM.
My car was plagued with this for years. Im currently having the vanos, rodbearings, cooling system, alternator all done along with new fuel filter, fuel pressure regulator, crankshaft and camshaft position sensors. If the car still fails to start on the first try I will have my injectors sent out for cleaning. The fuel pump was also changed but I will also be addressing the tube mentioned in this thread.
If the EWS internal relay shorts pin 1 & 2 when the key is present how would directly connecting them be any different than a normal start condition?
The relay does not short out pin1 and pin2 together. Pin2 is the signal from the ignition switch when turned to START, and when pin2 is 12v, then the internal "relay" connected pin1 to either pin10 or pin11 (system uses 2 pins for redundancy).
One needs to add a relay which is controlled by pin2 to connect pin1 (to starter) to power source pin10 or pin11. If not, the ignition switch contacts for pin2 will be burned and pitted soon.
I'm not sure exactly which chirping noises you're referring to in the first video
Originally posted by ATB88 View PostWhat exactly do you mean here? You mean get the car rolling with the engine off and do a rolling start in 2nd or 3rd gear? I'm wondering what your trying to test here? Some problem with first gear? Since the problem is intermittent, it could be difficult to conclusively test if we can get a hard start from a rolling start or not.
Sorry I haven't look at this thread until now.
The wire going to the starter is significantly heavier gauge than pins 10 or 11. I suppose if those 12v supplies are properly fused I guess it doesnt matter
Thanks for the info.
Chirping at 0:04, 0:05, 0:27. But as you said these were not related to engine.
Yeah, do a push start or rolling start and this will tell us if the engine will fire up without hesitation as compared to using the starter to crank it. For whatever the reason, if the starter gear doesn't release from the flywheel properly, this might cause the issue you have, and so I suggest to do a push start to see the same result or different.
