Womp.
Looking forward to seeing how the high temp dust boots hold up on my friend’s car.
Really hoping they hold up, as I don’t want to be dealing with heat shields (or, worse, both combined aren’t enough).
Porsche Brembo 996 BBK Conversion-- let's figure out how to fix the dust boots
Brembo dust boots did not survive a track day. Granted, this track day was extra long, so the brakes got a good workout. 7, 30 min sessions vs the regular 5, 20 min sessions.
Setup was 996 calipers, ZCP rotors, PFC08 pads, titanium shims and brake ducts (which are kinda useless with the new rotors). Even with the cooling/heat shielding, this still happened:
That was the only boot that fully failed, but I found a few others that were a bit melted. Replaced with a girodisc one for the time being. I'll likely replace all of them before the next track day just to see how those hold up.
That was day 2 of that pad being used...
... though admittedly in a caliper that got stuck.. Past half point on the pads, this kit just doesn't have the capacity or evacuation efficiency. Once combined with rotor being less than half life, it gets more interesting yet, need to keep optimizing. FCP might drop our warranty sponsorship if we keep sending back half good pads/rotors.
Originally posted by nyc951 View Post
Just my gut feel says there is something to that. The thickness and mass of the new brake pads creates a thermal barrier for the caliper and boots. Do folks use titanium heat shields as well? Like these:
https://girodisc.com/titanium-shield...c2s-c4s-front/
To reiterate, I run 1mm (believe thickest they make) Ti shims with Vorshlag cooling deflectors (which move more air than hoses) and still have issues with dust boots.
Originally posted by mrgizmo04 View PostYou need to know what kit you have, what generation, what size (diameter as well as thickness rotor) 355 vs 380, x32 vs x35, they would have different piston diameters to ensure correct bias.
That page from Zeckhausen is only useful if you are replacing pistons and know exact diameters you need as well as what generation your caliper is. It only shows that they are split into different height/length of the piston, depending on the generation, however the diameters of the pistons are different.
For example, a 355x32 ST40 kit uses 42/38mm pistons, a 355x32 ST60 (pic below) version uses 36/36/30mm combination.
Interesting so all the pistons fit the st60 are the same size? Thanks.
I'll second the nod Pat McCleish. If anyone ever runs into technical issues beyond their scope, he's a great asset to call. He is a master at this brake stuff, he knows more about the specifics on these kits than anyone I've met. He's a real car guy too, so that helps. He once helped me out when I was in a real pinch and thought I had no options. He proved otherwise. Great guy to boot.
Originally posted by mrgizmo04 View PostAnother random thought I had as partial(full?) solution to baked dust boots and to not have them pop out when pads get low...is to run new pads every track day (or at least replace at 50%?). You need something to absorb the heat, as the pad wears, it can take less energy and conducts more of it to pistons (Ti shims can only do so much as a barrier, at some point they get oversaturated too). As pad wears, pistons protrude more out of the bores, and as the pistons heat up, they conduct the heat to the hot air around them/dust boot. And the dust boot on a protruded piston is a bit stretched/stressed so melts/cracks as it absorbs all that energy. Air is a poor conductor and is an insulator. So if the pistons were more retracted into the bores (what happens when pad is newer), heat exchange would happen between piston and bore/caliper as well as fluid in caliper, so dust boot would not absorb as much energy to melt. That's what engineering hunch is telling me.
Ian's first pic shows pads rather low and pistons protruding, was similar case when mine developed crack from heat.
This is obviously not wallet friendly or FCP warranty policy friendly, but I Iike to share my random wannabe engineer thoughts. 🤣
Anyone know the E46 M3 Application Stoptech ST60 and ST40 piston sizes? Thanks.
Obioban Thanks for the link to Automotive Brake Solutions. I'm going to order some seals and pads from him once i get the above info.
How do the yellow and blue compounds compare in the real world?
Good to know FCP are carrying these now. Related: They also carry red/blue/yellow and Hawk DTC-60 for the D1001 shape of the Megane RS and DB9 calipers.
I went with DTC-60 because it was all that was available at the time, but I am curious about the EBC offerings.
I might try Pagid yellow29 pads at some point as keep hearing positive vibes on those.
Originally posted by mrgizmo04 View PostFor the rears you would be looking at non S Boxster fronts. They offer quite a few, Hawk dtc60, Ferodo ds2500 (you might be able to get away on rears, depending on skill level), Pagid RSL29, Pagid 14/44 (backorder), and looks like they just started with EBC - yellow/blue are the "track oriented", red are street and are super low dust/no noise but high initial bite (those who like Textars might give them a shot, but I melted them on BBK on s2k in canyons, I never ran Textars, so can't compare exactly, but red street performance was stellar though, ymmv depending on car use case).
Porsche Boxster Disc Brake Pad parts online. Buy OEM & Genuine parts with a Lifetime Warranty, Free Shipping and Unlimited 365 Day Returns.
