Best Transmission Fluid
    I use redline MT90 but I don't drive it on the street. Works good when the trans is warm. I've used D4ATF in the past. It feels good for a couple of weeks and then its really difficult to rev-match downshift.
    The best bet is OE fluid. Which is now DCTF? Anyone tried that?
    You can still buy MTF LT2 from BMW.
      Did Pentosin start making it again? For a while everyone was out of stock of even the BMW branded stuff.
        I suspect Castrol is making it.
          First link is a conventional (non synthetic) gl5 lube (rear end). We want full synth gl4 tranny lube
          Second link is DCT fluid that pentosin says is backwards compatible with the gl4 spec. I don't quite trust them.
            I used royal purple because it was at the shop and it's really notchy. I guess I should go to OE and see if it helps.
              Thanks, 10k miles ago I changed my transmission oil with liqui moly 75w90 . Transmission shifts smoother with liqui moly than redline but still feel difference during cold weather. Should I change it to oem oil?
                75w90 is too heavy for a street car except maybe one that lives in the desert or gets run hard. I would go to a straight 75w (mtf3) or OEM (bmw or pentosin) 75w80 mtf 2.
                  Putting Redline D4ATF in your transmission is great for shifting, since you'll be getting a new one shortly after.
                    Thank you guys !
                      Well crooked commie, I tend to disagree with your opinion ,FWIW , which we all have one ,so far my tranny has gone over 50,000 miles with the redline d4atf....
                      for street. Works great...
                      2004 M3 Mystic Blue
                        What automatic transmission did you install?
                          That's Redline's opinion too, problem is, all the synchros I've used it on tend to disagree. The track car got switched to Ravenol MTF-2 and all high rpm grinding magically went away.
                            Gear oil is gear oil is gear oil. I don't think your steering is powered by an automatic transmission?
                              ... no, it isn’t.
