Originally posted by Obioban
View Post
Best Transmission Fluid
Redline doesn't recommend an ATF for a manual transmission because they were dropped on their heads as children, they do it because they believe the specs warrant the recommendation... whether that's accurate seems to be up for contention around here, but it has nothing to do with the product name on the label as the post I quoted was implying.'03.5 M3 SMG Coupe - Jet Black / Black
I was implying the product label matters? Wtf
and your analogy doesn't work my ps system was made to be used with atf unlike the getrag so I'll stick with spec. You wanna go off spec just based on what the company says or did you look at voas and uoas?DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
https://www.bimmerworld.com/Fluids/D...ion-Fluid.html
anyone tried pentosin ffl-4? does it work as advertised?
im about to change fluid, do i buy 2 liters or 3?Last edited by sev; 05-15-2020, 01:26 PM.
My friend has it in his, but drives very little so hard to give feedback. Seems fine. Damage to synchros wouldn't show up for a while if it didn't have gl4 spec additive protection. Viscosity spec is close, so it should "feel" fine right away.Originally posted by sev View Posthttps://www.bimmerworld.com/Fluids/D...ion-Fluid.html
Wait you just said RP is pure crap so why are you gonna try another non-spec fluid?
Is there something really wrong with spending $35-40 on pentosin or ravenol gl4 75w80 spec fluid?DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Yeah this is something I really don't understand. People are willing to spend $150 on proper spec diff fluid but not trans? It's not like you're changing this every 3-5k miles like your engine oil, just get the right fluid ¯\_(ツ)_/¯Originally posted by Tbonem3 View PostWait you just said RP is pure crap so why are you gonna try another non-spec fluid?
good point. i could get the redline locally and was being impatient. maybe i'll just order the oe fluidOriginally posted by Tbonem3 View PostWait you just said RP is pure crap so why are you gonna try another non-spec fluid?
Hate to bump this but... didn't see any mention of this Febi fluid: https://www.fcpeuro.com/products/min...id-83220403247
Did it not get mentioned because it's already known to be crap? Anyone tried it?'03.5 M3 SMG Coupe - Jet Black / Black
Hypothetically, If someone was trying to learn how to heel to toe, and grinded their gears missing a shift, does the transmission fluid need to be changed?Garage:
2002 BMW M3: Slicktop jetblack/cinnamon. SMG to 6-speed. Arc-8's. Koni yellows/Dinan springs. Macht elbow. Megan headers. Stock section 1+AR20. SCZA section 3.
2001 BMW 740i: Original timing chain guides (I think).
2021 BMW X4 M40i: Dinan Intake.
