In a recent post I outlined how I used a boroscope to examine the rear cavity on the RACP before injecting structural foam to strengthen the rear subframe mounts.
The boroscope images in that post clearly showed that the rear cavity is completely enclosed and that pre-drilled holes at the top of the cavity can be used to inject structural foam to surround the left and right rear subframe mounts.
After examining the front cavity with a boroscope, it is clear that a similar same approach can be used to surround the left and right front subframe mounts with foam.
Here is a picture of the left top side of the RACP (facing towards the rear of the car).
All four holes are factory drilled. Holes A and D are tapped for the rear left seat hinge brackets, B is tapped to hold the rear left seatbelt, and C is unused and has a factory plug.
The left front subframe mount sits between holes B and C, though is slightly closer to hole B
In inserted the boroscope into hole C to examine the left side of the cavity.
Here is a view of the left front subframe mount inside the cavity. The top and bottom of this mount are welded to the ceiling and floor of the cavity.
Here is a view that also shows the underside of holes of A and B. A red ZipTie is inserted into hole B.
Unlike the rear cavity, which extends uninterrupted for the width of the car, the front cavity appears to have a panel in the middle, though it has a circular hole in it.
So, it is not reallly neccesary to inject seam sealer into this middle section to seal off both sides. (In fact, I don't think it really is needed for the rear either since the foam is unlikely to reach that point even when cured.)
Here is a view from hole B towards the side of the car.
As can be seen, the cavity terminates immediately after hole D.
The goal of foam injection process is to bond each mount to the RACP by completely surrounding it with foam.
For the left front mounts, holes B and C above make the most sense as injection points.
After injecting one 420ml container into hole B, I inserted the boroscope into hole C to see where the foam ended up.
Here is a picture of the left front mount immediately after the injection of structural foam into hole B.
As can be seen, the foam is beginning to surround the mount even before the curing expansion process - which is exactly what you want to see.
After foam is injected on the other side of the mount it will be completely enclosed - and bonded to the RACP permanently.
For completeness (and to verify that the cavity is symmetrical side-to-side) I also inserted the boroscope into the right side of the cavity.
Here is a view of the right front subframe mount inside the right side of the cavity.
And, finally, here is the right front mount after foam is injected on one side of it.
