I’m looking to replace the headlight lenses on my e46 m3 and was wondering if there are other cheaper options than the oem ones which are like $100 for each side. I’ve seen some URO ones but not sure if I should cheap out just do it once right. In the end tho, it is just plastic so not sure how different they could be. Any thoughts or recommendations?
Headlight lens replacement recommendations
Another member suggested you could order both Uro and Genuine BMW then return the non-OEM stuff if it doesn't fit, however if you end up scuffing it up during installation etc. you may not be able to return them.
I might just order this and feel like a sucker, $$$.
Was doing this job on an old beater and figured why not give it a shot on my sandblasted lenses before I opt to replace them.
Sanded them down and hit it with 2k clear, which I figure will be more durable than new plastic anyways. Still need to knock down the orange peel but in my book that's $200 better spent elsewhere.
Sent from my iPhone using Tapatalk'04 LSB Coupe 6MT
I’ve done this on other cars, it does work. But others beware that the clear spits out a ton of overspray that will get everywhere. Very fine particulates. Wear proper mask and protect everything with plastic and proper masking. Obviously the removable lens’s of the e46 make this much easier.Originally posted by dukeofchen View PostWas doing this job on an old beater and figured why not give it a shot on my sandblasted lenses before I opt to replace them.
Sent from my iPhone using Tapatalk2003 | 3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
I cheaped out on an Ebay set for like $35 for the pair like a year ago. They look fine but now are starting to yellow, so ill definitely going OEM next time.
But one thing, I know there are Xenon and Halogen model OEM versions, is there really a difference?2004 M3 6MT | Eventuri Intake | 3.91 | Wavetrac
2006 325Ci SULEV |ZF 5MT Swap | Koni Yellows | H&R | 330i Brakes | Magnaflow Catback | AFE | APEX ARC-8 18x9 |
Yeah, the 2k clear calls for an organic vapor-rated respirator cartridge. Cover your skin, wear goggles, and do it in a ventilated area, that hardener is nasty stuff.Originally posted by oceansize View Post
I’ve done this on other cars, it does work. But others beware that the clear spits out a ton of overspray that will get everywhere. Very fine particulates. Wear proper mask and protect everything with plastic and proper masking. Obviously the removable lens’s of the e46 make this much easier.'04 LSB Coupe 6MT
I used Hella on my old e46zhp and for the next few years I had the car they held up fine. And since it's FCPEURO, you have lifetime replacements. Seems like a no-brainer.Originally posted by D-O View PostI went with the Hella parts from FCP Euro. Fits perfect. Looks great.
D-O
Question for the hive - how many removed entire headlight assembly to replace lens, versus replacing lens with headlight still on car? I've seen videos doing it both ways. I'm bringing the entire front back up to code, corners, lens and beauty strip.Interlagos 06 M3, Autologic tune, Agency Power midpipes/exhaust, Fortune Auto coilovers, UUC SSK, Bluebus, Lightwerkz retrofit. MRegistry listing here
