Okay, and there's another piece of info I'm missing. Does the line that links the left side to the right side (through which the venturi effect makes gas go) run inside the tank? (I'm trying to rule out misconnected hoses during reinstallation. It would not be fun to have to drop that tank again...).
To consider:
the car ran fine for 5-10 minutes, meaning at least the most crucial lines were connected adequately.
Another thing I was thinking is if the venturi line connecting both sides runs inside the tank, might I have messed/crunched up something by tightening the top nut of the tank (the one in the center of the car)?
The other theory is that everything is correctly connected (my buddy helped me remove the tank and we were too quick on this, I didn't take pictures and had to figure the plumbing out upon reassembly), but my fuel pump is failing, and not pumping enough volume for the jet pump to work adequately.
To consider:
