Crank no start
    Crank no start
    So I filled up my tank with gas 2 days ago, drove the car fine. It always gave me a hard start first thing in the morning. 2nd crank and it starts up fine.. so today after work . Tried starting the car it cranks but don't even turn over like it wants to start, thinking a fuel issue maybe . No check engine light, I changed plugs and coils a few months back , when I did my vanos. Now on the way home got the car towed. When it's time to take it off the flat bed. The car started right up. Where should I start looking? The car starts up fine now.
    Check for codes first. If no codes, then it sounds like a failing fuel pump.
      No codes, right now.
        Inpa looking at ews module error and status
        I think it could be ews to dme synch issue
        or signal from ignition switch to Dme is intermittent.
          I'm going to do the fuel pump and filter. Since I bought the car about 8 years now, I never changed it. Is oem the only way?
            Grab fuel pump from bimmerworld. They have Hella OE branded one for $99.
              So I pulled the code through inpa. Got fuel pump relay. So it's a relay problem. Where is it located and where to buy a new one?
                ​It's located in right side of the trunk just forward and up of the battery under the trunk covering (Black relay/EKP).
                BMW M3 parts online. Buy OEM & Genuine parts with a Lifetime Warranty, Free Shipping and Unlimited 365 Day Returns.
                Click image for larger version  Name:	image.png Views:	5 Size:	878.5 KB ID:	238192
                  Thanks , I'm going to change the relay and also the pump and filter too.
                    Also is this part replaceable the part the tow hook goes into?
                      Have to replace the reinforcement bar. Kevlar bar?
                        Does anyone have a pic of the mount the tow hook goes into, I'm trying to see if it's replaceable. Or have a part # for the mount?
