E46 M3 injector below:
| Injector type | OE NR. | Type | Info production stop (status 01.2008) |
offer drawing | Resistance (Ohm) | Test medium | Operating pressure (kPa) | Q-stat (at operating pressure) (g/min) | Q-stat with 300 kPa (g/min) | Q-stat with 300 kPa (ml/min) | q-dyn with 300 kPa, ti 2,5 ms (g/1000 Imp.) | Spray type | Spray angle alfa-50 (for 2 beam) |
Spray angle alfa-80 (for cone-characteristic) |
axial deviation angle (spray bent angle) | Spray orientation angle | Spray distribution (area, spray amount) | allowed fuels | Version, type | Electrical connector | locating lug (anti rotation device) | hydr. connection to manifold | hydr. connection to fuel rail | Distance between O-rings (O-Ring to O-Ring) |
Total length |
| 0280156052 | 0 280 156 052 | EV 6 | A 280 434 251-114 | 12 | Heptan | 400 | 223 | 193.1 | 276 | 6.32 | E | 15° | ¤ | 10° | 270° | >30% | E85 | Design 96 | Jetronic | no | O-ring variant | O-Ring standard | 48.4 | 61 |
These 3 below all flow very slightly less, but seem close enough otherwise that they'd probably be plug and play without retuning and letting adaptions do their thing
Total length |
| 0280156066 | 0 280 156 066 | EV 6 | 12 | Heptan | 400 | 219 | 189.7 | 271 | 5.63 | E | 15° | ¤ | 10° | 270° | >45% | E85 | Design 96 | Jetronic | no | O-Ring standard | O-Ring standard | 48.4 | 61 | ||
| 0280156070 | 0 280 156 071 | EV 6 | 12 | Heptan | 400 | 219 | 189.7 | 271 | 5.63 | E | 15° | ¤ | 10° | 270° | >40% | E85 | Design 96 | Jetronic | no | O-Ring standard | O-Ring standard | 48.4 | 61 | ||
| 0280156071 | 0 280 156 071 | EV 6 | 12 | Heptan | 400 | 219 | 189.7 | 271 | 5.63 | E | 15° | ¤ | 10° | 270° | >40% | E85 | Design 96 | Jetronic | no | O-Ring standard | O-Ring standard | 48.4 | 61 |
The ones below flow more, but may be reasonable options with a minor tune adjustment
Total length |
| 0280156061 | 0 280 156 062 | EV 6 | 12 | Heptan | 300 | 217 | 217 | 310 | 6.9 | E | 15° | ¤ | 10° | 270° | >45% | E85 | Design 96 | Jetronic | no | O-Ring standard | O-Ring standard | 48.4 | 61 | ||
| 0280156062 | 0 280 156 062 | EV 6 | 12 | Heptan | 300 | 217 | 217 | 310 | 6.9 | E | 15° | ¤ | 10° | 270° | >45% | E85 | Design 96 | Jetronic | no | O-Ring standard | O-Ring standard | 48.4 | 61 | ||
| 0280156142 | 0 280 156 143 | EV 6 | 12 | Heptan | 300 | 217 | 217 | 310 | 6.9 | E | 15° | ¤ | 10° | 270° | >45% | E85 | Design 96 | Jetronic | no | O-Ring standard | O-Ring standard | 48.4 | 61 | ||
| 0280156143 | 0 280 156 143 | EV 6 | 12 | Heptan | 300 | 217 | 217 | 310 | 6.9 | E | 15° | ¤ | 10° | 270° | >45% | E85 | Design 96 | Jetronic | no | O-Ring standard | O-Ring standard | 48.4 | 61 | ||
| 0280156063 | 0 280 156 064 | EV 6 | 12 | Heptan | 300 | 269 | 269 | 384 | 8.5 | E | 15° | ¤ | 10° | 270° | >45% | E85 | Design 96 | Jetronic | no | O-Ring standard | O-Ring standard | 48.4 | 61 | ||
| 0280156064 | 0 280 156 064 | EV 6 | 12 | Heptan | 300 | 269 | 269 | 384 | 8.5 | E | 15° | ¤ | 10° | 270° | >45% | E85 | Design 96 | Jetronic | no | O-Ring standard | O-Ring standard | 48.4 | 61 |
I don't know enough about injectors to say for sure whether we can deviate on spray angles and how much room we have to mess with the length.
