I know there's a post about what people are using on their guide pins but I cant seem to find it. I had been using the ATE plastilube but due to that post I tried wd40. While it has made them cleaner and a bit more free they do tend to stick once the wd40 is cooked away. Anyone else have a magical lubricant they use?
Caliper guide pin lube
I clean them hospital-clean with no abrasion marks on the pin. I don't use lube and have no issues. If the barrel is sealed with a cap (my brass bushing don't support a cap), I suppose you can use any lube (I once used copper anti-seize) but I don't want any compound that can collect brake dust or fine road grit.Last edited by Estoril; 11-28-2023, 11:01 AM.
I use and recommend Sil-Glyde Silicone Brake Lubricant. https://www.agscompany.com/products/...rake-lubricant
ATE notes that Plastilube can be used on slide pins. Not sure how it compares to other products.ATE Plastilube Brake Lubricant, the best choice for noise-free brakes. ATE Plastilube provides long-lasting protection and reduces maintenance frequency for brakes. Plastilube provides an exceptionally long service life, to keep all moving parts lubricated and in smooth operation, regardless of weather conditions.Last edited by Will; 11-29-2023, 07:22 AM.
Yeah, I read that--I could see how one could interpret it that way but I stick to metal on metal as I've just had great results with the Toyota stuff, in a sliding caliper, with steel pin and sealed rubber boot.Originally posted by Will View PostATE notes that Plastilube can be used on slide pins. Not sure how it compares to other products.
On my M3, last brake job I ran new ATE pins, bushings dry and I had sticking problems (bushings too tight, out of tolerance?). So, I hit them with the Toyota "grease" and zero issues--just like on my Lexus as the official TIS calls for on that vehicle. I'm not confident that in the BMW TIS the word "grease" = "lubricant". Rather, the word "grease" may = "some kind of grease not suitable for this application (rubber swelling, washout, etc.)".
And, not to mention, these slide pins should be cleaned/inspected/replaced along with the bushings as a matter of maintenance. So, yes, they may get dirty, but cleaning is a matter of maintenance and if maintained seizing is mitigated. That's how I roll this all up anyway. I guess we can chock this up there with the debate on adding angle to the torquing of the skid plate bolts.
