Puretech x-brace install
  • bavarian3
    Originally posted by fourmula1 View Post
    If this is just a street car you are probably more than fine slotting the holes on the tabs ever so slightly. In theory there would be a little play but probably wont matter once you torque everything down.
    If you really want it solid, install the tower plates and torque them down, install the x-bar through the chassis and torque down, and then weld the x-bar to the tabs on the plates and forego the bolts all together.
    Yep figure this is what i'll do as a last resort, I do like the welding idea better though.
    Based on this pic they don't seem to be off by much.... maybe your car is just off by a millimeter after 20 years?
    Is the car on completely flat ground?
    Originally posted by robgill View Post
    I've installed two of these. I would loosen up the bolts on the top of the tower bracket. Then line up and install the 4 bolts in the cross brace. Now tighten down the 4 bolts on top of the tower. Last step is drill and install the 4 horizontal tower bolts. I dont see any issue with the horizantal gap but you could insert some washers if needed.
    +1 on make sure the car is on the ground
    I did this method and that's how I ended up with the gap.
    To answer the question about the car being on the ground, it certainly isn't. It's lifted on quickjacks. It currently has no rear suspension. I only bolted in the subframe itself to do the x-brace install. I didn't consider this(car being off the ground) initially.
  • robgill
  • 9kracing
  • fourmula1
  • bavarian3
    started a topic Puretech x-brace install
    For those who installed the pure-tech x brace, how well did the hole line up for you between the shock tower plates and the x-bar?
    I tinkered around with different ways to get this aligned before I do any drilling into the shock tower and the holes don't line up.
    I checked to be sure the tower plates fit fine, which they do, as shown. No gaps or issues.
    Now trying to align the x-bar...driver side holes align perfectly
    but the passenger side...
    If I try to put the bolts through the x-bar and tower plates first, then secure the tower plates to the tower, i end up with gaps like so...
    Puretech claims they haven't seen this issue before. My car is pretty darn clean and unmolested so I'm not thinking it's racp or shock tower uniformity issue. Only thing I can think is when I drill the holes in the tower the bolts will pull things in where there's gaps, concern is deforming the shock tower make this happen.
    What does everyone think?
    [Tagging robgill and liam821 from some previous threads I found on this topic.]
