375-380mm rotors/discs under 18" wheels
    How often do you rebuild the calipers with fresh seals and etc?
    So far, never. Still performing like new, so haven't seen a need.
      That’s pretty incredible considering the number of track miles, wow...
        Yep. As I said, they're one of the mods I'm happiest with on my car. I can certainly see why so many OEs choose them, including Porsche, Ferrari, etc.
          The Brembo 355/4s are lighter than the stock rotors/calipers. Maybe (don't know) more rotational inertia, but lighter.
          The benefit to 6 pistons is larger pads, which gives you longer longer pad life. I don't think it's worth the trade off, but that is a benefit... the only benefit AFAIK.
          I have to say, my Brembo GTs (355/4 front, 345/4 rear) are one of the best mods I've done to this car. I've now had them for 14 years/140,000 miles/20,000 track miles, and they've been 100% flawless throughout that entire time. I believe they are the only mod I've done to the car that I haven't later redone with something else/better. I can't see any room for improvement. (well, I see the allure of free rotors/pad by using FCP, which they don't allow, but that's no fault of theirs... and I decided that benefit wasn't worth the trade off in performance).
          I only went with the 355 kit because I'm running 17's on my car for actual driving haha. Can't fit 380's under a 17. That would be insane.
          I rebuilt the GTR calipers prior to installing them, wasn't cheap but titanium pistons aren't known to be. Absolutely awesome kit but I need something in the rear since it's just a stock setup with matching pads and lines. Was thinking about making an E38 Brembo fit the rear stock rotor since I don't want to run a Brembo GT kit in the rear/I can't find a rear set with slotted rotors.
          2005 BMW ///M3
          Black6MT Daily
            This kit above will do the job perfectly for most track days and it saves a lot of $$$. Unless you are running a full time race car, other brakes are just overkill.
            I am very happy with my Stoptech Trophy kits - 355mm.
            2005 IR M3 Slick Top 6speed. Mods - too much to list!
            18 R8 RWS.
            19 Vantage
            15 YMB F80 M3 DCT - gone
            Other cars too boring to list.
              Somewhat on topic, where do you guys source 355x32 rings for best prices for Stoptech kits? Not sure if they cross fit with Brembos? Too bad FCP does not do them.
              Youtube DIYs and more
                Zeckhausen. They will work on Brembo hats. IDK if any modification is required or if hardware needs to be swapped over, I just get Brembo rings and cry.
                2005 BMW ///M3
                Black6MT Daily
                  Left Slotted -
                  https://www.amazon.com/Centric-31-73.../dp/B004HED5OI
                  Right Slotted -
                  https://www.amazon.com/Centric-31-73...BWDMBHT1D5P9Q1
                    Yep I cry too when buying from them, but they are great guys to deal with.
                      Hopefully these don't disintegrate after 1 lap. Thank you.
                        I'm running a 355mm Brembo GT kit in the front with stock rears + brass guides / SS lines and I have never needed "more brakes" than what I get from this system. I can drive 40 minute sessions at Laguna Seca (notoriously hard on brakes) without any fade.
                        The front kit pays for itself overtime just by reducing service intervals.
                          We design, manufacture, and sell 2-piece, fully-floating brake rotors for Porsche, BMW, Subaru, and more. Made in the USA from US-sourced materials.
                          Girodisc makes 355 and 332 mm rings for StopTech/Brembo kits as well. Pricey but their stuff seems to be a cut above from my own experience and hearing from others.
                            https://www.girodisc.com/Rotors_c_1213.html
                            Yeah I've seen that page, which made me think that Brembo vs Stoptech might use same rings (maybe different hardware due to slightly different rotor hats, but not sure, and on Girodisc site you don't seem to need to specify, so maybe they are the same). Then I started wondering what oe (Audi/Porsche/etc) use Brembo in that size to be able to source the rings from FCP, but doesn't seem like FCP is in that business.
                              It would be amazing to find a 355x32 on FCP!
                                StopTech Rotors
                                To fit Brembo Brake Kits
                                StopTech replacement rotor rings come with mounting hardware included. StopTech mounting hardware is a different design than the Brembo hardware that originally came with your kit. Thus, you should follow these installation instructions, when mounting StopTech AeroRotors to your Brembo hats: StopTech Rotor Installation Instructions
                                In several sizes (328, 332, and 345mm) StopTech rotors have thicker mounting flanges than Brembo rotors. These mounting flanges may interfere with a raised lip on Brembo rotor hats. If so, an automotive machine shop can easily remove the lip from your Brembo hats in minutes, using a lathe. This is a minor modification that our customers have been doing for years.
                                From Zeckhausen here: https://www.zeckhausen.com/catalog/i...?cPath=82_1516
                                They would definitely know, maybe shoot them an email?
