Other than what you posted most stuff is race oriented splitters with either built in or modular diffuser tunnels. Maybe you can get someone to make something custom for you.
AJ Hartman sells splitter tunnels that can be integrated into a splitter. The problem with our platform is there isn't much room for a tunnel between the bumper and the tire. You'll have to cut away the underside of the bumper which provides some room.
There is a big difference between carbon and plywood...one of the few times where I think it makes sense to spend the $$$ on carbon. The key attribute is stiffness:weight.
I recommend starting with a plywood splitter so you learn what not to do. I cracked 2 wood splitters - one on a seemingly innocent dip in the paddock and then banged the splitter when pulling the car into a spot with a lift.
Stop fighting with your aero. Secure your front splitter with our track-proven, quick-release mounting systems and heavy-duty support rods. Universal and vehicle-specific kits available.
Try these, they alow the splitter to move up in case of a problem but don't allow it to move down.
