I’m in the process of doing my subframe. When I pulled my drive shaft I noticed the grease inside the cv joint was pretty nasty. I was looking into replacing the joint itself and noticed in the kits there is a grease cap that comes with them. I don’t have a cap and I don’t believe anyone has ever had the drive shaft off. Is this normal
Driveshaft CV joint.
The M3 does not have that cap. Clean the snot out of it with brake cleaner and then repack it with Castrol Optitemp 2 LN 584 LO (BMW # 83190447919). https://www.fcpeuro.com/products/bmw...0g-83190447919
And be sure to replace the gasket while you're at it. https://www.fcpeuro.com/Parts/?keywords=26111229503
- Likes 6
Thankyou.Originally posted by BMWE46M3 View PostThe M3 does not have that cap. Clean the snot out of it with brake cleaner and then repack it with Castrol Optitemp 2 LN 584 LO (BMW # 83190447919). https://www.fcpeuro.com/products/bmw...0g-83190447919
