Windshield Manufacturer & Compatibility Questions
    Originally posted by bimmerfan08 View Post
    Given this response, I assume a new windshield seal isn't supplied and installed during the repair, correct?
    https://www.fcpeuro.com/products/bmw...er-51318208468
    No - its just that aftermarket seals have a spotty record.
      Seems like it's a bag of mixed reviews which is what I gathered when reading about windshield manufacturers on other forums.Thanks for the replies everyone - things to think about and scrutinize.
      IMO - Step 1 is contact your insurance and see if you can take it to the dealer. If it's covered, your decision is easy.
        Missed the comment earlier - apologies. Have tried this route. Insurance wouldn't cover the dealer's quoted price for the job. IIRC, the dealer was going to outsource it to a glass company, anyway.
          Sounds like you're in good hands overall. Pilkington is indeed one of the OEM suppliers for BMW, and if that's what Safelite is using, that's reassuring. Still, I'd double-check if it's OEM-grade or aftermarket-spec Pilkington. Sometimes the difference is subtle, but it can matter in terms of optical clarity, thickness, and tint.
          Good catch on the rain sensor. As long as it's properly seated and calibrated, you should be good. I’ve seen a few cases where rain sensors acted up post-installation, but they were fixed with a recalibration or re-seating. Since you’ve already replaced the cowl and it's in great shape, there’s no urgent need there, but you might want to ask if the urethane adhesive or trim pieces are being replaced—some shops reuse them, but fresh ones can make a big difference in long-term sealing and noise reduction.
          I’ve been doing some work recently with a glass manufacturing company in Chicago and it’s been interesting learning how different layers in laminated auto glass are constructed—especially regarding UV protection and acoustic insulation. Makes me appreciate how much more there is to a windshield than just the glass itself.
            Looks like all genuine windshields are out of stock? Even aftermarket I've only had my local glass providers be able to source Fuyao. No signs of Pilkingtons.
            What is everyone else's experience?
            🔹 2001 M3 Laguna Seca Blue
            Instagram: link
            Build thread: link
              I had been dragging my feet on replacement after I got a crack on the highway a month or so ago. I called 3 local places and only one could order a Pilkington. Fuyao was all that the other shops could get. My zhp got a Fuyao when it needed a windshield and it always seemed to fog worse than stock.
              Anyway, when the new windshield showed up, it was a "TriVal" brand. The tech showed me prior to install and said this happens from time to time with older cars. The windshield had Pilkington stocking labels and stickers which was a little odd. My 5 mins of Internet sleuthing found that TriVal is related to Pilkington somehow but it's still "Chinese glass". I had him install it anyway as I was a little sick of dealing with it. I can get some pictures but it seems nice enough? Realistically, my car doesn't see enough miles to determine hardness/pitting long term. I used an OEM seal so I'm not worried about leaks. It has provisions for the wiper sensor and the OE style "green" band.
              2003.5 SG/Grey
                I was able to have an installer find a green band pilkington in december- seems like i got lucky but for anyone looking it seems like they might still (or at least were) be some stragglers around. What id do to have infrared again though….
                  The place I use said there was possibly 1 OE factory windshield left in the country and would cost $1K. Said that OEM Pilkington was available for $550 (takes 10 days to order). OEE is Fuyao and is $495.
                    I just had to buy an OE one. So pissed at the price. I'm going to PPF it this time.
                      Hi, everyone. My M3's windshield needs replacing. I don't recall if it's original glass (not near the car at present), but I haven't replaced the windshield in my 13.5 years of ownership. I have an upcoming appointment with insurance handling it. Their default installer is Safelite.
                      The part number for the glass is FW02456GGY on the work order. I called Safelite and asked for the manufacturer of the glass to which they responded Pilkington. Just like sourcing the right StarknightMT UTV accessories getting the correct parts listed properly matters. My M3 is equipped with a rain sensor which has been noted on the work order. A separate line item for a new rain sensor with part number GGG2163 is listed.
                      1. Pilkington is one of the original suppliers of glass for our cars, correct?
                      2. What else do I need to be aware of with a windshield replacement on our cars? Any concerns/issues that are common? Especially those that have had Safelite replace windshields on these cars.
                      3. Are there any other parts that should be replaced during the process? Seals, etc.? I replaced the windshield cowl a few years back, so it's in excellent condition.
                      Thanks
                      Yes Pilkington is OEM approved for BMW so the glass quality is solid. Main things to watch out for is making sure the rain sensor gets properly recalibrated after install and check for wind noise on a highway test drive the same day since that is the most common Safelite complaint on BMWs. Ask them to inspect the trim molding during removal as it can crack, and consider replacing the seal while everything is already pulled out.
                        Last year, I caught a rock on the windshield and had to get it replaced. The BMW certified body shop could not get an OE BMW windshield for my car at all. They procured a Pilkington, which ended up being Chinese. The rain sensor and auto light sensor work fine, but there is some distortion at the edges.
