Need help with a parts list-shocks/springs
    I'm getting ready to have my subframe reinforcement and Eibach/Koni yellows installed, trying to make a complete list of all the parts I need- the car's an '04 convertible with 84,000 miles. I looked at some of the parts kits ECS and FCP sell, but don't want to order a kit and still be missing parts or end up with parts I may not need. Thanks in advance
    my list so far:
    RTAB
    rear subframe bushings
    front/rear shock/strut mounts
    rear shock mount reinforcement plates
    bump stops
    spring pads
    Here is the list of parts I assembled for a complete front and rear suspension refresh. You may decide not to do all of these (e.g, front control arms).
    ------------------------- Front Hardware ----------------------------
    Front shocks (2)
    Front springs (2)
    Front Upper Strut Mount - Left (31332229165)
    Front Upper Strut Mount - Right (31332229166)
    Front support plate (31332229427) (2)
    Front bump stop support (31321139423) (2)
    Front bump stop (31332229778) (2)
    Front dust boot (31331093344) (2)
    Front lower spring pad (31331096664) (2)
    Front upper spring pad (31331091233) (2)
    Front upper strut bearing (including seat) (31331090612) (2)
    Front lower control arms (31122229453, 31122229454)
    Front control arm bushings (31122229623, 31122229624) (2)
    Front anti-roll bar bushings (31351126577) (2)
    Front anti-roll bar end links (Meyle HD) (31356780847) (2)
    Tie Rod - Left (32112228785)
    Tie Rod - Right (32112228786 )
    Tie rod boots and clamps (32131096910) (2)
    ---------------------------- Rear Hardware --------------------------------
    Rear shocks (2)
    Rear springs (2)
    Rear shock boot (33521136283) (2)
    Rear shock mount gasket (33526788999) (2)
    Rear shock mount plate (33526762325) (2)
    Rear shock mount plate (with rubber gasket) (33526788999) (2)
    Rear shock mount washer (33526779398) (2)
    Rear bump stop (33532229777) (2)
    Rear upper spring pad (33531136385) (2)
    Rear lower spring pad (33531094518) (2)
    Rear inner control arm upper bushing (33321092247) (2)
    Rear inner control arm lower bushing (33326770824) (2)
    Rear outer control arm ball joints (33326775551) (4)
    Rear trailing arm bushings (33322228153G) (2)
    Rear anti-roll bar bushings (31352229711) (2)
    Rear anti-roll bar end links (33552282182) (2)
    Front subframe bushings (33312283573 and 33312283574) (2)
    Rear subframe bushings (33312283419) (2),
    Differential-to-subframe bushing (33172282484) (1)
    Differential cover (with 2 integrated bushings) (33112282482)
    Loctite for differential gasket (83190404517)
    Differential fluid 0.5l (83222282583) (3)
      Don't forget 2 of 33526772864 paper gasket between shock mount and body
        I also forgot two rear shock mount washers (33526779398). I have updated list above with this number.
          Very helpful-thanks!
            Is this that important? Honest question.
              I would say so. They've there to keep water, mud, etc from coming into the car.
                That's very helpful thanks. I am also planning to refresh my suspension with B12 kit and GC street camber plate. Would the same list apply including the upper strut mounts and spring pads?
                  I would coat them in rtv let it dry and use them. They're paper ...absorb water, but I coat mine for rust protection of the body where the shock mount contacts the chassis.
                  Just a little thing.
                    It is also a 44c part if you go OEM aftermarket.
