Front end links (replacement) for ST XTA coilovers
Turner has adjustable endlinks in various lengths. Measure current endlinks and check sizes - https://www.turnermotorsport.com/p-3...s-pair/?pdk=Ag
KW endlinks are not as good as the rubber boot falls off very easily, but you can order a set from KW/ST directly.
Part number is Meyle 15-16 060 0007/HD they are 180mm.
Part is readily available here in Europe, if you want I could ship you a set if you need it fast, or just get some adjustable ones like the others said.Last edited by bmwfnatic; 02-14-2024, 10:53 AM.E46 ///M3 • 12/2002 • phönix-gelb • 6MT
Originally posted by bmwfnatic View PostPart number is Meyle 15-16 060 0007/HD they are 180mm.
these look similar based on what i can see on google, but every description says “rear” - and I need fronts. Is that correct?
This is likely the same thing as the popular KW "MOOG" match people figured out years ago. There's a thread on these forums about it as well.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by MTL_ZCP View Post
thanks!
these look similar based on what i can see on google, but every description says “rear” - and I need fronts. Is that correct?E46 ///M3 • 12/2002 • phönix-gelb • 6MT
I bought these on Amazon years ago I needed them fast, they are labeled as KW but they are just Meyle HD links with a crazy price tag. Seems like the same as the 180mm Alfa links, I never measured mine. That current price is insane lol, I would probably just get the Alfa links or adjustable if I was to buy them today. This part number 68510000 in google shows them being sold for less at other places and verifies the 180mm.
https://www.amazon.com/dp/B019QIVLVS...roduct_detailsLast edited by Norocehcap; 02-14-2024, 03:17 PM.
