Tested and Ready 70° and 75° Thermostat
    Yes I did. I will ship this week.
    Thanks,
    Anri
    Great stuff, thank you Anri.
      Hi,
      Thanks for you reply. Yes I have more left.
      PM me if you want one.
      Regards,
      Anri
      Returned my 55C thermostat. I am ready to buy a 70C if you have any available.
        I sent you PM.
        Regards,
        Anri
        www.euroclassicmotors.com
          I sent you PM.
          Regards,
          Anri
          Can you please also reply to mine .
            Hi Mike,
            I am sorry I forgot to reply on your
            PM. I just did.
            Regards,
            Anri
              Hi Anri,
              DM sent for payment info.
              Cheers
              Mike
                PM'd Anri about a 70C thermostat
                Update: I was able to get his phone number from his Instagram Bio and order it that way got a reply same day on a Sunday. I will update as well when it ships so others have an idea on lead time.
                The price now is $220 Shipped.
                Build Thread:
                  just to give everyone an update. 70c tstat is great. def keeps temps a lot lower when cruising around the streets. at the track it didnt make a difference of course since the car gets to temp and hot. But it did cool down the motor a lot since it will keep kicking through the radiator up to 70C versus the OEM.
                  But Im not sure if its the only thing since I also updated the radiator and fan clutch
                    You can use those number to interchange to other manufacture.. e.g. ACDelco part # is also available. Etc.
                    You can even buy these thermostats from Porsche as they compatible with the Carrera GT.
                    https://motorad.com/part/880070/#interchange​
                    https://motorad.com/part/880080/#interchange​
                    https://motorad.com/part/880090/#interchange​
                    Did you try these? I don't think they fit. They are bigger in diameter and do not fit the housing.
                      I have one but i never got round to installing it
                        Hey Anri,
                        Don't know if this was covered but with the 70 degree tstat where does the temp needle sit on the gauge cluster?
                          Did you get the Motorad? I ordered the Motorad 880060 as Gates 33576 and its huge. Comparison in picture. Left is S54, right is Gates 33576.
                            Yes, ok so that's that then LOL. I guess it'll go on the shelf.
                              You versus the guy she told you not to worry about. 🤣
                                Thanks for sharing your experience, its for sure win win.
                                I have mentioned times and times that the t stat will NOT change the peak
                                temp at the race track. But but but it will prolong/delays the heat soak ones
                                you begin the session which allows you to buy more laps.
                                Fan clutch with early engagement+bugs free AC condenser is must.
                                Regards
                                Anri
