Tested and Ready 70° and 75° Thermostat
    Originally posted by Grke46m3 View Post
    Hey Anri,
    Don't know if this was covered but with the 70 degree tstat where does the temp needle sit on the gauge cluster?
    Hi,
    Usually the needle sits around 2mm past the dot on the temp gauge.
    Make sure your AC condenser is free of bugs and also Sachs fan clutch,
    to take full advantages. Just buy those OBD ports from online and you can
    plug it to OBD port and your phone and you can monitor the temp while you
    are driving.
    Regards,
    Anri
    www.euroclassicmotors.com
      Originally posted by m3_sancho View Post
      Did you get the Motorad? I ordered the Motorad 880060 as Gates 33576 and its huge. Comparison in picture. Left is S54, right is Gates 33576.
      Click image for larger version  Name:	IMG_7445.jpg Views:	15 Size:	87.1 KB ID:	304563
      Sancho,
      The T-Stat on the right is from E39M5/E34M5.
      The Motorad is garbage brand which is not operating as advertised.
      I have tested them many times and they never ever open at the advertised
      Celsius.
      Let alone that tons of people from other car manufacturer ended up with
      stuck closed thermostat which you don't with our BMWs...You don't want
      to play cheap in this area believe me...
      I will say it again, I DO NOT USE Motorad garbage as some people may possibly
      think I do.
        Sachs Brand I believe is NLA for our cars. that is not good. They sell like a
        hot bread...I don't know why Sachs no longer makes those....
        Behr is not my cup of tea.
        Hunt for Sachs Fan clutch left over in parts stores NOS (new old stock) I am sure they are out there
        sitting on shelf.
          Thanks for sharing your experience, its for sure win win.
          I have mentioned times and times that the t stat will NOT change the peak
          temp at the race track. But but but it will prolong/delays the heat soak ones
          you begin the session which allows you to buy more laps.
          Fan clutch with early engagement+bugs free AC condenser is must.
          Regards
          Anri
          agreed, it definitely delays the peak temps by 1 lap or 2 depending on the track. But on the street it takes longer to warm up esp in the FL heat.
            Gents,
            To each to our won for sure on this one.
            Not very constructive replies..
            Inline 6 cylinder engine Cast Iron block
            is waaaaay too long.
            When the cooled water from the radiator
            enters from the cylinder 1 it takes the heat
            up to cylinder 3 aka Bank-1
            Starting from Bank-2, 4-6, the water already
            took the heat from Bank-1. Now Bank-2
            has Hot water to work with and its no longer
            cool when it entered the block.
            Factory design water pump impeller and
            pulley ratios are designed to work at 8000rpm
            without making Cavitation, this is the concentration
            I am sure we all agree on this one. Mechanical
            pump are always concentrated to work at hi rpm
            and low rpms are always compromised. (this is
            were the Electrical water pump is priceless one
            can adjust the flow at low speed to move the
            water faster)
            Lower range of RPM is compromised when
            the water is slowed down tremendously and
            thus why Bank-2 works always hot vs Bank-1
            Obvious reason why BMW moved to step water
            temp gauge starting from E32/E34. On the E24
            E28 when the temp raised degree by degree I can see it
            on the gauge..I can see when the clutch engages and
            brings the temps down...isn't that obvious ? all the S54
            cylinder head gaskets are always burned at Bank-2 okay
            not talking about the ones that suffered damages
            via detonation.
            Why BMW put the EGT sensor on Bank-2 not Bank-1 ?
            Bank-2 runs always hot
            The Block Deck height on S54 is 217.5mm+/-
            How come no one talks about that BMW Motorsport
            raised the Floor by around 15-17mm ? (I have to look at my notes)
            its to increase the rigidity in the main bearings
            area by taking some space form the water bath.
            On S38 at the same deck height of 217.5mm the water
            bath is deeper down by those 15-17mm is what I am
            comparing with so they did good on block from 1965
            but went backward on 2000 engine block.
            With connecting rod ratio of 1.52 the siamesed
            bores do receive a lot of heat and with the combo
            of 8000rpm for sure its Heat-Bomb
            How come no one talks about that the EGT from
            the headers which easily reaches ~850/~1000F/ 590°C or
            so are located around no more than 1 finger away
            from the block, fantastic, you have 900F radiant heat
            going directly to the cast iron heat sponge.
            I will provide very deep detail data on Jonathan's
            freshly put S54 together, you will see.
            Starting from Jonathans M3 I am including this in every
            engine build.
            All arguments and debates are all welcomed.
            Regards,
            Anri
            Would you recommend heat wrap or ceramic heat powder coating for the headers to keep the radiation heat lower?
              Regards
              Anri
              Hi Anri, Thanks for the thermostat.
              What do you mean by "bugs free AC condenser​"
                Meaning clean the bugs out of fins
                  Thanks but what how does the AC Condenser affect engine temperature?
                    Sits forward of your radiator so if it’s dirty or clogged it will restrict air flow and your car won’t cool as efficiently.
                      I have been waiting for mine to ship since May 9th. I have been following up once a week.. beware for anyone ordering. Usually don't like to put people on blast but this is getting ridiculous.
                      Edit: Just got tracking #
                      Build Thread:
                        Anri is a super busy dude, took a while for mine, but I got it.
                        Fair enough point made though, just don't want anyone thinking he doesn't do what he promises. Anri is legit.
                          Thanks for your kind words. I have way too much on my plate with my current custom project, usually I wait till I get bulk
                          of parts to ship at ones, otherwise I will be at the post office every day....
                          I think you asked if I still have those for offer, yes still do.
                          Regards,
                          Anri.
                            I always say "Every little helps" it will help to keep the radiant heat away from the block for sure.
                            I have done/tested every header coating on the market including Swain-Tech which I use only for look to be honest. Nothing
                            can beat heat shield or header wrap...I mean no coating in existence can get near to that efficiency.
                            If coating is a must, Swain-Tech is my choice over the rest. Also the silver header shield work very well as well with very clean look.
                            Regards
                            Anri
                              Is there any power benefit to running the S54 cooler than 175F/80C? At what temperature is too cold?
                              This is in regards to a race car, 55C motorsport thermostat has the car running at 165F/74C in the mornings and I suspect in colder weather will go even colder. At warm-up idle it will only get up to 140F. Thinking about swapping back to 80C so the S54 doesn't drop below 175F/80C at full tilt.
                                Won't the car run rich? I don't see any benefit from running the coolant lower than 170f. If anything, it makes it THAT much more difficult to get the oil temps up. Sometimes takes me 3 laps to get to 210f oil temps and I'm using the stock thermostat.
                                I've been thinking about going with a smaller radiator and much bigger oil cooler or a non-M radiator and a full face oil cooler on the back. I think the OEM M3 radiator is too big for track use with the OE ducting and fans deleted. The most efficient setup is to stack the oil cooler behind the radiator, the colder t-stat would likely provide a significant benefit in that setup.
