1. do you have to turn off the key and crank again to have the engine running? If yes then maybe the starter solenoid/Bendic is going bad.
2. did you try with another key? Could be ews and DME synching issue. Use inpa to read the ews status
3. they are not related.
1. Yes I would try to start the car and it would crank over and over but not start. I then put the key to the off position, wait a second and try again and it will start up fine.
