Originally posted by sapote
Carbon Fiber driveshaft do it
Originally posted by George Hill View PostThanks for the review, one question though. Can you measure the diameter of the CV joint and length of everything with the extensions?
We had a similar style one piece DS in a car and the flange would hit the body at times (even with fresh bushings).
(only pic I have of it, now has a stock style shaft in it)
One would be wise to only install a carbon driveshaft in combination with solid subframe bushings. It would be a real bad day to crack and split a carbon shaft on a launch or hard 1-2 shift.‘02 332iT / 6 | ‘70 Jaguar XJ6 electric conversion
I think the CSB went bad and that's all. CF is light and so no need to have CSB.
Originally posted by Bry5on View PostI had this issue in my EV conversion jag after adding all that torque. It was the subframe rocking on the bushings that allowed the driveshaft to lift upward on torque application.
With that said this car does make way more power than most S54 cars, so might not ultimately be an issue for most.
'00 R11S, '09 HP2S, '12 R12GSA, '00 Gray 332iT (SOLD), '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Japan Rot 325iT
