He need to replace flexible/rubber line, hardline and spring load bracket on both side, and probably front too.
BTW the hardline comes in straight section so you will need to bend them yourself so might have to drop rear subframe and fuel reservoir to do the job
Would I be able to cut just the rusty areas and replace it with a new ones, or everything should be one piece only, and I have to to the intire hard line?
You can cut where the hardline isn’t rusted, put a new fitting, redo a new flare and make a new line in between
