V2 Diff rebuild + Gear Ratio Swap
    To close the carrier I use the same method I used to open it, get to as close as I could, the. Zip tie it and use a hammer to tap the tool and lock it in place.
    Click image for larger version  Name:	IMG_1837.jpg Views:	0 Size:	137.7 KB ID:	300761
    the final torque was a bit lower than what I expected, but it is very similar to how it was before, this makes me think the unit was still ok, also the clutches looked fine!
    Click image for larger version  Name:	IMG_1838.jpg Views:	0 Size:	115.7 KB ID:	300760
    I was able to close the unit to where it was. I also shimmed the side gear with the play, and it is much reduced now that the unit is closed. I used 2 0.1mm shims with RC40 harness for durability.
    Edit: took a photo of the carrier closed to the original position with it set screw to lock it.
    Click image for larger version  Name:	IMG_1849.jpg Views:	5 Size:	124.4 KB ID:	300776
      This is how I measured the pinion to confirm if I needed to change the depth shim, and by how much.
      First I setup the pinion on a precision block, and align the micrometer so that I could have the exact same setup for both pinions, I started with the old one
      Click image for larger version  Name:	IMG_1840.jpg Views:	0 Size:	116.7 KB ID:	300763
      I also rotated the pinion to verify the runout, it is incredible that the micrometer did not move at all as I spun the pinion.
      Here is the original one
      Click image for larger version  Name:	IMG_1839.jpg Views:	0 Size:	94.3 KB ID:	300764
      and here the new, same, no runout as I spun the pinion, they are cut exactly the same.
      Click image for larger version  Name:	IMG_1844.jpg Views:	0 Size:	99.2 KB ID:	300765
      then it was all about getting the pinion into the carrier and adjust the preload
      Click image for larger version  Name:	IMG_1847.jpg Views:	0 Size:	106.8 KB ID:	300767
      Click image for larger version  Name:	IMG_1848.jpg Views:	0 Size:	101.7 KB ID:	300766
      Edit: spent time in ISTA last night and reviewed the specs for e36 chassis, and found that the pinion preload should be 2.5nm or 250ncm. I will redo this as I fear I may have screwed up the process.
      I also found the carrier preload values which are bearing brand dependent. Will add here.
      K = kompact or small
      M = medium
      G = grob or large
      Click image for larger version  Name:	Captura de pantalla 2025-04-07 074943.png Views:	0 Size:	25.4 KB ID:	300798
        The carrier preload seems totally loose, so will need to adjust it and start the gear mesh setup from scratch
        I hope it won’t be too difficult
        Edit: false alarm, I just had to torque the side caps, it is 2nm of preload, which is about midway the spec.
        i also gave the pinion a tad more preload to match the side and it is 2nm also.
        base on all this I should have little trouble setting the gear mesh.
          More info on that puller!
            This is the one. I bought the version with two cups (orange and black) the one with white adds another size option.
              https://www.vevor.com/bearing-inner-...le202412&gQT=1
              F my life...where was this 3 years ago? lol
              Just bought one.
                1. so before closing the carrier I wanted to see if I could make the ring close to the original position, to my surprise it goes to the same place with and without clutches.
                2.The carrier preload seems totally loose, so will need to adjust it and start the gear mesh setup from scratch
                1. I don't see the pump in the pics but assume you had it when tightening the ring; if no pump then I don't see how you know the locking ring is at its final position.
                2. What side caps that affects the pinion bearing preload? The output flange bearings preload should not affect the pinion bearing preload.
                  1. man, you should go back and check. I documented the ring was drilled and tapped before opening, that is how I know it went to its home position. Also there is a photo above.
                  2. Did not I say CARRIER? Not sure why you are inferring anything related to the pinion.
                    1. I was referring to your new post's pics showing the locking ring installed but no pump.
                    2. My bad.
                      More “progress”. My expectation that the pinion depth was going to be ok was wrong, despite the pinion top face being equally tall on both, the center point relative to the ring and housing may be deviated and so my depth is a bit shallow. The contact is centered heel to toe, but to close to the face of the tooth. also the backlash was almos same as before, 0.06mm. So I guess RD is not entirely correct, and is still possible that the depth needs adjustment, and not the side shims.
                      Without tools I will need to do some trial and error and find shims that get me there, I found some original shims ranging from 3.755 to 3.835, so I will aim for the tallest and go from there. I feel I may need a bit more than that, but also some small moves go a long way.
                      So up for the 3rd round of pinion removal.
                      Pro-Tip, if you are doing this, DO NOT change your bearings until the very last, as the races are delicate and this thing is heavy, so by removing and installing the carrier from the housing, you risk damaging the races, I also on the first go tightened the pinion much and it did score the race, so my OCD forces me to replace it, so will be at least two sets of bearings.
                      Here an image from TIS I used to tighten the ring, is not same as ours, but it helps to follow the correct pattern
                      As you can see backlash was nice and tight with original shims
                      Now the deal breaker. First image is drive, the second one is coast.
                        So for the noobs, is the coast too inset?
                          Not an expert, but the pattern appears to be slightly closer to the face.
                          Crawlpedia is an off-road encyclopedia featuring a detailed guide to set up ring and pinion gears with the proper gear tooth contact pettern.
                            Yeah, pinion pre-load and crush sleeve is the LAST step.
                            Set backlash and pattern and THEN change the pinion bearings, races and seal unless there is obvious damage.
                            I think the 3.85 is the cutoff to where you may need a different shim. The pinion head get smaller as the ratio gets shorter. Then there are the tolerances stamped on the pinion.
                            Sorry, I would have said something. It’s been awhile since I’ve done this. I do remember always having extra carrier bearings on hand because they can get banged up since you need them installed the first step.
                            Empty diff case
                            Carrier preload (need nee bearings/races on)
                            Install pinion (no seal or crush sleeve)
                            Set back lash / gear pattern
                            Disassemble and clean diff (careful with the carrier bearings)
                            Replace pinion races
                            Install pinion with crush sleeve and seal
                            Set preload
                            Install carrier
                              Click image for larger version  Name:	IMG_1861.jpg Views:	4 Size:	90.8 KB ID:	301287
                              Click image for larger version  Name:	IMG_1862.jpg Views:	4 Size:	82.1 KB ID:	301289
                              I'm not surprised that measuring the pinion gear head length on the precision table turned out not a reliable method to find pinion depth. Since the end of the pinion gear usually edged or stamped with the matching pair numbers and other information, so its face is a rough uneven surface, not a reliable for any dimensioning purpose. Most manufacturers added the unique pinion depth on this face so the installers don't have to do trial error method to set the pinion depth.
                              On the gear pattern, I would use less of the gear marker paste -- only a thin coat -- for a clearer pattern.
                              Yes, it shows the pinion needs more shim; I would add additional 0,010 to 0.015" shim to see how far the contact pattern moved toward the bottom of the teeth, then reduce the shim if needed.
                              I would add a sencond the gear marker 180* from the first marker just to be sure the installed ring is flat.
                                I finished up setting up the diff. I only added 0.1 shim to the pinion bearing, and now that have seen many online photos, I am not sure I needed to shim it at all. Feel free to comment, my first pattern was a bit high on the tooth but also had a bit larger area, with the 0.1 shim it lowered a bit but the coast side seems thinner? I think is very minor and is fine either way, if it was not so difficult to remove everything again, I would probably take the 0.1 shim out.
                                all other things came out perfect
                                2Nm of friction torque for the pinion and carrier unit
                                0.0025 of backlash
                                i never updated about the timesert I had to put on the front bushing joint, but that was done also.
