To close the carrier I use the same method I used to open it, get to as close as I could, the. Zip tie it and use a hammer to tap the tool and lock it in place.
the final torque was a bit lower than what I expected, but it is very similar to how it was before, this makes me think the unit was still ok, also the clutches looked fine!
I was able to close the unit to where it was. I also shimmed the side gear with the play, and it is much reduced now that the unit is closed. I used 2 0.1mm shims with RC40 harness for durability.
Edit: took a photo of the carrier closed to the original position with it set screw to lock it.
