Hi all, I've been chasing my tail with a very nasty valve tick for the better part of a year now. Hoping the collective knowledge here can help me find a solution. The tick is coming from exhaust valves on cylinder 6 - it sounds as though the valve clearance is significantly out of spec, even though it is well within spec. The car drives fine and doesn't feel down on power in any way.
I have gone as far as changing the cams and followers-- this motor has been through some hell in a previous life, and I was not sure the cams/followers were matched, so I swapped in a 68k mile matched set. That did not help.
I have also checked for exhaust leaks at the headers and found none.
Valve springs are intact and seem to be in good shape.
Compression test is good at 180psi across the board (the engine had the head gasket replaced and ARP head studs installed).
My question is - besides the valve lash and worn valvetrain, what else could be causing significant valvetrain noise? At this point I'm about ready to swap in a refreshed cylinder head, but hopefully it won't come to that.
Thanks in advance!!
Thanks in advance!!
