Vert roof clicking issue to worse
    Hey folks, before I give up and bring it to a top guy - anyone have any experience with the clicking sound issue with your roof not working, going to fix it, taking the cover off the motor under the seat, then it stops working entirely?
    As in no movement of the motor at all? Tried reseating the sensor and gear, putting the cover back on and now no movement at all. The buttons up front flashes red, when you press it it stops flashing entirely and still nothing happens. No sound of motor or any movement.
    Thank you
    Wish I could help but if nobody here chimes in, I think you'll have more luck in the convertible subforum over at e46fanatics as the vast majority of active members here own coupes. I've found some nice and useful vert information there.
      Thanks, posted there as well. I appreciate it
        This will likely solve your problem
        https://www.ebay.com/itm/BMW-E46-325...g/303569863805
        Edit: you can also do this:
        So guys I was looking to fixing my convertible because it was making a horrible clicking sound when putting the top down. The whole system to be replaced costs $1,100 brand new and about $200 used...... So I set out to fix it myself. I couldn't find much on this forum so I decided to...
        https://www.facebook.com/media/set/?...0399866&type=1
        3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
          Yep, read the "start here" sticky link at the top of the e46fan conv forum
            Hey thanks but the original issue was the common gear popping out of place which turned into nothing is moving at all now. I'm not sure how a new cover (though that is a good idea instead of the ziptie / pipe clamp method) will get the motor spinning again.
              Thanks, plenty of stuff about the clicking issue but nothing about why it would stop working entirely. oh well
                ^Gotcha.
