After several years of doing autocross, I am shifting more towards doing track days. Since I am no longer building the car to a rulebook, I'd like to improve the suspension. The current setup is pretty typical of SCCA FS class:
Before I order, I intend to educate myself on flat ride so I can order the right spring rates. But in the meantime, I could use some help picking out an approach so I can know how much to budget. Here are the options I am currently weighing, but of course I am interested in anything I might have missed:
- Tires: whatever super 200s are hot each year
- Suspension: Koni yellows with stock springs, TMS front bar, all bushings OE but refreshed
- Brakes: DTC60 pads on stock calipers/rotors
- Ground Control Coilover Conversion + Ground Control Camber Plate $570 + $440
This seems like the most cost effective route, by reusing my existing shocks. But am I going to be under-dampened? Also, I assume this will reduce bump travel? Maybe other bad side effects? - TCKline Single Adjustable kit $2500
This kit seems like the best deal on a quality all-in-one kit, but I'm not sure how much I would truly gain over option 1? - Ohlins Road and Track + camber plates $2400+$440
Similar to option 2 but a bit more expensive. Including because so many reviews seem to like this kit.
