Traction Control/Yellow Brake Light?
    Originally posted by LeeForst View Post
    Yep that was it - just ordered 2x to replace both
    Figured so. They are a PIA to replace.... need very tiny hands, but is doable. pro tip, pump the fluid out of the resevoir, otherwise you will evacuate it through the sensor hole when you remove it. big mess
    2006 M3 ZCP 6spd
    2008 M3 6spd
    2012 LP 570-4 Super Trofeo Stradale
    2014 Ferrari 458
    Follow me on instagram @ biggreasytaco
      Why not put saran wrap/rubber glove/etc at the top of the fill hole (with rubber band/zip tie around the threads) to hold as vacuum, then you shouldn't lose any fluid and can avoid the bleeding. At least that's my plan when I get to it over next few weeks.
      Sent from my SM-S911U1 using Tapatalk
      Youtube DIYs and more
