Originally posted by ATB88
If the leak is coming from the same two grommets, then there could be an issue with that valve cover or you have to throughly clean the mating surface. The studs are not removable without removing the cams. I would not worry about the guide tube seals. Mine does that on random cylinders and I just clean out the small amount that is there. I have no idea how it gets in there other than condensation. Spark plugs are completely dry.
