Originally posted by oceansize
The OE BMW bolt grommets, however, are still very lightly weeping from the top center bolt holes. 3-4 of them. I check every few drives and wipe with a microfiber to avoid them leaking onto the valve cover itself. I'm considering just repeatedly replacing them with new ones from FCP to see if it's just a probability thing and some of them just don't seal as well because of the washer being wonky or something. If that doesn't help, I'll probably end up using a little bit of JB weld between the bolt head and washer.. I bet that'd do it. Really annoying that I'm still getting small leaks with new OE hardware though. I can't trust them enough to put the beauty cover back on the engine :/
As for the spark plug tube seals, because new ones are so insanely expensive now, I stuck with my older OE BMW ones that I installed in 2020. Since my recent service, I have not had any oil leaking into cyl 2 spark plug well, and I've been checking often. So, I think that my problem there was either that my valve cover was not properly evenly torqued before, or that the bolt grommet leaks around cyl 2 were so bad that oil was just finding its way into the cyl 2 well and not the others. I really hope that the OE non-BMW elring seals are just as good, though, because $42 a piece for BMW is dog****.
Yeah it'll be interesting to see how you fare. I definitely recommend keeping the beauty cover off for the first month so you can easily inspect after random drives without any overhead. Part of me wonders if a lot of people's leak like this but nobody notices because they just throw the beauty cover back on right after service, and the leaks are so small/slow that it could take quite a while to notice.
