Hit a deer....need some help on parts
    So yeah that sucked. Had about 3 seconds to jump on the brakes as it ran out of the woods and juked left/right and then tried to play Sants's reinder in front of the car. But the little fucker missed both front fenders, the bumper (has scratches now from hooves), the windshield and (the best part) no airbags deployed. Drove the car home and have now torn it apart. Everything between the headlights (including both headlights) is trashed. Radiator got pushed back into water pump / water pump pulley and mangled the Spal fan but missed my 12 year old BW CF intake by 1/2 inch. Verified the frame rails are straight (about 10 times lol). All and all, I consider myself extremely lucky. Anyways, looking for current recommendations for the following parts (as in, which manufacturer is the one to get).
    Hood
    Radiator support
    Driver / pass side bixenon headlights
    Kidney grills
    Water pump
    Water pump pulley
    Radiator support (sides of rad)
    Radiator (research says Modine is the way to go)
    AC condenser
    Power steering cooler
    Power steering lines to/from cooler
    Crank pulley (small dent from radiator tapping it)
    Things not trashed by deer but original equipment or need to be replaced due to wear
    Coolant expansion tank
    Clutch
    Any help is appreciated.
    Mike
    02 M3 Titanium Silver / Black
    11 Tundra SuperWhite / Black
    I have a feeling most people on this forum is going to tell you to go OE with most items on the list. I don't have enough experience or knowledge on the platform to really give meaningful advice but below are the choices I made on my purchases so far or who I would go with
    Hood - find used? or maybe splurge on the Karb cf hood?
    Radiator support - probably OE, although how bad could off brand be here?
    Driver / pass side bixenon headlights - find used for pretty cheap with all tabs and send them off to Lightwerkz
    Kidney grills - i like OE here
    Water pump - big thread on this forum about going OE because the impeller on the OE is preferred?
    Water pump pulley - idk
    Radiator support (sides of rad) - idk
    Radiator (research says Modine is the way to go) - idk
    AC condenser - i went with denso via rockauto i believe
    Power steering cooler - idk
    Power steering lines to/from cooler - i think rein is okay, not sure
    Crank pulley (small dent from radiator tapping it) - idk
    Coolant expansion tank - OE?
    Clutch - idk​
    also, sorry to hear about the deer. when i was 16 some guy in a truck hit a doe in front of me and waved me down to help him move the deer off the street. huge mistake...wasn't dead and it started kicking when i grabbed its hind legs. felt like every tendon tearing apart in my arms as it was freaking out. welp, won't do that again.
    /// 2004 SG/IR - Build Thread
      OP is why I always inspect cars thoroughly and never trust the carfax.
      2004 Dinan S3-R M3
      2023 X3M Competition
        Most of the body parts I’d probably find a part-out nearby and just pick and pull. Might be able to swing a PS cooler and AC condenser from a part-out car too. Water pump & pulley, power steering lines, radiator, and expansion tank, I would go OE. Also, I would see if you can get away without changing the crank pulley depending on how bad the damage is.
        ‘02 TiAg/Impulse Slicktop
          Insurance claim already made and about 200 pictures taken of car for any potential future sale. Plus I’m not a scumbag. Any input on the original question?
          Mike
            ^ This. A part-out should get you most of the parts and you can probably go new on some of the maintenance items.
              If this happened to me, I would strongly consider buying a convertible or a rear ended car to part out. If you have the space and some time, you could get everything you need for your repairs, and probably come up on the rest pretty decently if you do it right.
              '01 M3, Imola/black
                Im on vacation at the moment but i have all the factory pulleys and belt in my parts bin. I can mail them to you for the shipping cost, if you want
                  Definity take the guy above me up on his offer for the pulleys, those are expensive when bought new.
                  Radiator should be NRF now, they no longer come Modine labeled but supposedly from the same company.
                  Hood and radiator support shouldn't be that hard to find used.
                  For the headlights the left side is 'different' for the M3, but you can also buy them from a normal E46 if you move over the module and the longer M3 wiring (assuming that is still in good shape).
                  That should be a bit cheaper compared to getting 'M3' headlights.
                  Kidneys just get them new from BMW.
                  Water pump from BMW, the aftermarket ones suck.
                    The front radiator support can be hard to find and the last time I checked used parts seemed kind of ridiculous.
                    If it was a track car I can make a carbon part. Won't well for a street car. Unfortunately, I made the mold from a modified part so its missing the part where the headlight support screws into.
                      PM sent. Much appreciated.
                      Mike
                        Depending on milage I would refresh known maintenance items with new stuff and find parts for the rest.
                          This is where I'm headed. I've owned the car for 20 years and don't see selling it anytime soon. 137k on the car and about 25k of that since it stopped being a daily drive in 2012.
                          Mike
                            So far hardest to find is a good condition used hood that isn't 8 hours away. Thanks for the info on the headlights - have to look into that.
                            Mike
                              Hood
                              Radiator support
                              Kidney grills
                              Water pump
                              Water pump pulley
                              AC condenser
                              Clutch
                              Mike
                              I'm parting out an Interlagos coupe in CT and have some of the parts you're looking for if interested.
