I have a DTC for the MAF sensor on my S54 swapped e30. I verified that the wiring pin out is correct so I can only assume it’s a bad sensor. I also had the same thing happen on my M3 a while back. Is it that common for the MAF to go bad on these engines?
Is Bosch the only go-to for replacement? I see Delphi can be had a little cheaper but there seem to not be many alternatives. Any suggestions?
