Anyone install a trunk handle backup cam?
    Just purchased this trunk handle/backup cam to install and set up with my Eonon head unit:
    Does anyone on here have experience with this type of camera install? I don't think I'll need to cut/drill into the trunk fascia, I was thinking I would just pop out the old handle and pop the new one in, does that sound right?
    It also looks like it needs to be powered additionally (not from the head unit) and says to connect the camera's power cables to the reverse lights positive and negative. Is that easy to do/self-explainitory? I don't want to be stripping any cabling/cutting/drilling to perform this install.
    Thanks!
    Not seeing how that would work since you lose the trunk open button, maybe one that replaces the license plate light lens instead?
      I believe it incorporates the trunk open button + backup camera in the same part so you shouldn’t lose functionality of opening the trunk. It was only like $25 so if it doesn’t work out it’s no big deal.
        I would guess your biggest issue will be that the hole in the handle isnt rectangular. Youre going to have to cut either that piece, of the handle. Fwiw, i have an old trunk handle in the trash i just replaced, if you want it to see if you can modify it, im down in dover. I dont mind meeting you halfway, or just mailing it if you cover shipping. Just a thought
          using T-Tap connectors should be sufficient to make your connections, but these cheaper chinese units are never plug and play. you'll probably need to do some crimping/stripping/taping/finessing to get everything buttoned up
            In the pics, it looks like there isn't a trunk button, only the 1 power and 1 video signal cable. If you're okay with losing the trunk opening button on the trunk itself (and just using the remote, or the button in the footwell) then it should be okay.
            Yes, you can use T-tap connectors, just make sure you use pliers to squeeze the blade down to guarantee that you have sufficient contact.
            Personally I just drilled a small hole and mounted the camera a bit off to the side. Not a fan of the license plate light cameras, and I had this camera on hand for 5 years, as it came with my car.
            To be honest it is hideous, literally a black pimple on the back of my car. I do have to take the trunk handle off again to install a missing trunk handle gasket, so I'm going to colour match the camera housing with some touch-up paint
              If you have the LCI trunk handle, there is nothing to pop out. There is no separate trunk button part -- the rubber portion of the button is "stuck" on the main piece of the bottom/black part of the trunk handle. To use those eBay trunk handle cameras, you have to saw/dremel a hole into that piece. Secondly, most trunk handle cameras I've seen are too long (e.g., 11cm or more) and too wide (e.g., 4cm or more), not even considering the portion of those cameras that will have to live inside the trunk handle itself. The recessed area for the button in between the recessed areas where the screws go is only 10cm long and 3cm wide. You have to cut into the portion between the two recesses to fit the 11cm ones.
              ​​Click image for larger version
              The camera-only solution is a better option (until an E46-specific trunk handle option comes out) but I agree a bit that those ones look like a "black pimple" ... not sure if it would look better if the camera is painted body color.
              The OEM retrofit camera is less visible but you have to cut through the metal so it's a bit more work. Have had the kit for several years and have never gotten to install it. Also bought a trunk handle (both painted and black pieces) and an eBay camera to find alternatives. Maybe by the time these lockdowns are over, I would have installed something!
Name:	e46 camera 1.jpg
ID:	27770 Click image for larger version
ID:	27771 Click image for larger version
ID:	27772 Click image for larger version
Name:	e46 camera 3 (1).jpg
ID:	27773 Click image for larger version
Name:	e46 camera 2.jpg
ID:	27774 Click image for larger version
ID:	27775 Here's how I did mine. Used a stand alone unit. The trunk handle cameras are not made for the E46 despite being advertised as such, same with the license plate light ones. Fitment is horrible.
                  Here's how I did mine. Used a stand alone unit. The trunk handle cameras are not made for the E46 despite being advertised as such, same with the license plate light ones. Fitment is horrible. Click image for larger version
ID:	27777 Click image for larger version
ID:	27778 Click image for larger version
ID:	27779 Click image for larger version
ID:	27780 Click image for larger version
ID:	27781 Click image for larger version
                    That's annoying! Will try to return that piece. That DIY job of yours turned out really well! I'm just wary of drilling into the trunk's facia like that, don't want to make any permanent changes.
