Whats a good affordable scan tool that can reset airbag lights , adaptations , etc.. if it can communicate with a converted CSL dme that would be a plus.
Which scan tool
Scanning tools i use for both my Non-M and M E46 are:
INPA, BMW Scanner 1.4, and OBD Fusion with Bluetooth OBD module. I can always troubleshoot most issues with these items.2004 M3 6MT | Eventuri Intake | 3.91 | Wavetrac
2006 325Ci SULEV |ZF 5MT Swap | Koni Yellows | H&R | 330i Brakes | Magnaflow Catback | AFE | APEX ARC-8 18x9 |β
I an advocate of getting a cheap laptop and setting it up with INPA. Also you can buy a laptop already setup with INPA/ISTA, all the tools you will really ever need for about $500.
You can even buy a hard drive loaded with the software for around $80 if you have a cheap laptop already, you can have an old windows 7 or XP computer.
Yes a laptop isn't as convenient as a small scan tool but unless you buy a nice $2K SnapOn or Autel scanner you won't be able to have the functionality of laptop setup, and even then things such as a vanos test cannot be carried out with anything but the laptop.
If you want a few basic things and don't feel you will need to ever do any more than read/clear codes and reset adaptations a handheld scan tool is probably a winner.2004 Silbergrau Metallic 6MT
I'll make a thread on this once I test DME flashing and NCS coding using a virtual machine. So far, I have tested INPA (english version) and it reads codes, data, etc, but the person who posted the DIY seems to have tested many other BMW tools.
Credit goes to a forum member on e90post - https://www.e90post.com/forums/showthread.php?t=2030476
All instructions plus video are included in the post.
Macbook (Intel or M series, free if you already own one)
VMware (now free for personal use)
Windows 11 (ARM for M series Macbook)
ARM driver for OBD cable
BMW tools
INPA, NCS, TunerPro etc.
Should be a good, fast, low cost, one laptop solution.Last edited by Slideways; 08-06-2024, 01:06 PM.
Not exactly sure on the exact number, but I'm seeing about ~700mb with INPA and like ~4mb with BMW Scanner 1.4Originally posted by WoGGo View Post
Once installed, how much space does INPA & BMW scanner take up?2004 M3 6MT | Eventuri Intake | 3.91 | Wavetrac
