Originally posted by x X Cloud X x
Build a bear *differential*
FWIW, I just cracked 160k and my diff is still working well enough with no noise. It has been through 70k of fairly hard driving with me, including a number of trips around Lime Rock Park. I will say I never, ever launch the car though. First gear is just for getting moving. Stock diff bushings.
I think this may be the move for my V2 diff, just swap to a wavetracOriginally posted by Obioban View PostI assume you are on stock fluid, with FM booster? Stock diff is notorious for whining with anything else.
Failing like that, wavertrac is great for a street/track car. Silent, predicable, easy, no clutches to wear out.
V1 or V2 diff, or what is yours build month/year?Originally posted by 01SG View PostFWIW, I just cracked 160k and my diff is still working well enough with no noise. It has been through 70k of fairly hard driving with me, including a number of trips around Lime Rock Park. I will say I never, ever launch the car though. First gear is just for getting moving. Stock diff bushings.
I also never had any issues with the stock diff— either in the first 160,000 miles of life in my m3 coupe, with track time, or the 230,000 miles in the m3 wagon (almost entirely street use).
Both V2’s. Both with real fluid change intervals 😜
Originally posted by Obioban View PostI also never had any issues with the stock diff— either in the first 160,000 miles of life in my m3 coupe, with track time, or the 230,000 miles in the m3 wagon (almost entirely street use).
The only issue with the stock diff is the M clunk which mainly happens at moving from stop. My 87K miles V2 already has this issue. The bearings and pinion/ring are stout.
My v2 had the clunk when I picked up the car with 2 miles on it. Don’t think it’s an issue so much as a design choice.Originally posted by sapote View Post
