288/280 Cam Compression
    Hey Fellas,
    So I bought a motor that was said to have 190psi (stock cams). I put 288/280 cams in and now the psi is pictured.
    I'm surprised as the variance is HUGE.
    What are the compressions you guys are seeing with 288/280 cams?
    Are you guys seeing 360whp with supported mods (SSV1 2.5 system, CF airbox, etc)?
    Thanks,
    Kareem
    Lots of things affect cranking compression especially if you are comparing your results to someone else's:
    • Battery voltage
    • Engine Temp
    • Was the throttle WOT?
    • Flywheel weight
    • ETC
    Email to [email protected]
      My compression before 280/272 cold engine
      Cylinder:
      1. 162psi
      2. 169psi
      3. 170psi
      4. 165psi
      5. 173psi
      6. 172psi
      With cams obviously static compression drops all things remaining equal. I think after cams your stated compression is quite good. Pistons will claw back a lot of whats lost and more imo. In the dyno sticky I think BBR tuning did a very comprehensive test with new pistons and rods and noted some interesting things.
      With CSL, ssv1, and 280/272 and stock injector mine made 348whp on dynojet (engine @151k miles).
        288/280 Cat Cams, Mahle Powerpak 87.5mm pistons, Rogue steel LWFW. Amateur-built engine - no promises...
        cold
        1: 155
        2: 157
        3: 168
        4: 154
        5: 162
        6: 166
        hot
        1: 154
        2: 154
        3: 156
        4: 154
        5: 155
        6: 153
          cold
          1: 155
          2: 157
          3: 168
          4: 154
          5: 162
          6: 166
          hot
          1: 154
          2: 154
          3: 156
          4: 154
          5: 155
          6: 153
          These are about the same as my car w/ 288/280 cams.
          Mike
          02 M3 Titanium Silver / Black
          11 Tundra SuperWhite / Black
