Anyone have a recommendation for ordering touch up paint? Either a stick or spray. Front bumper needs some love (for now) but will most likely be replacing it prior to selling the car. Also have some small chips to fill
Touch up paint
Google automotive touch up spray and you will find multiple vendors offering made-to-order aerosol spray cans in whatever color you need (TiAg is paint code 354). You could also look for a local paint store near you. They'll usually mix it on the spot while you wait. Either way should run you $20-30.IG: @limited.slip
Alpine White E90 M3 6MT
Alpine White 1 Series M
T̶i̶t̶a̶n̶i̶u̶m̶ S̶i̶l̶v̶e̶r̶ E̶3̶9̶ 5̶4̶0̶i̶ M̶-̶S̶p̶o̶r̶t̶ T̶o̶u̶r̶i̶n̶g̶ S̶6̶2̶ 6̶M̶T̶
yeah, i think previous owner tried to repaint the bumper but it didn't go very well. Rest of the car is mint though. I will ultimately replace the bumper but for now, just try to clean it up.Originally posted by Inizes View PostI used Dr Color Chip and it was great. But it looks like your clear coat is failing, so I do not think it would work in this application.
I have used three:
dr color chip was a waste of money compared to the others
automotive touch up was decent but hard to get right and the paint can had a very poor sprayer.
touch up direct was the best match in terms of color, metallic and flake size for my steel grey. Ymmv but I have seen and used touch up direct a few times and it has been excellent.
Automotivetouchup was great for my tiag. Painted and cleared my door handles with their aerosol base/clear and used their paint stick for chips. However, for that front bumper I would pay the 300 to 600 for a shop to simply strip and repaint as it looks as though you have clear coat separation over a fairly large area.
If you know what you are doing where paint is concerned ignore the rest of my comments.
You will have to sand and strip down to primer and if you have never spot blended it is much tougher, to get right (any monkey can butcher it), than you think. You will more than likely botch the first attempt and be in worse shape than you started, hence you will do it multiple times
and that costs money. Not only that but plastic front bumpers are more particular than body panels.
Looks easy in this video but it isn't (I worked in a body shop for almost 10 years).
Ive used automotivetouchup.com for everything in the past. They are really good but big delays right now. You may have luck finding a local auto body supply store. I just ordered a aerosol from my local store to pick up and its cheaper than going online because of shipping. My local store is a Wesco but there are other ones.2002 M3 LSB/Kiwi Vert
2014 X5 50i
2019 Ford Raptor
