*RESOLVED* 2k to 4k rumble/vibration 2nd gear
Seems like when I replaced mine you needed to move the CSB forward (towards engine bay) 10mm to 15mm or so before tightening down. If you didn't do this, then perhaps...?2003 | 3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
Did you torque the bolt that holds the two halves of the driveshaft together? Recently had mine back out and it sounded exactly like a bad CSB.
Factory Specs Production date: 2002-04-16 Type Code: BL93 Body Type: Coupe Transmission: 6MT Exterior Color: Topasblau (364) Interior: Powered, lumbar, non-heated, black nappa (N5SW) Options: Sunroof, HK, CD53 Misc: MK20, MSS54, M11 rod bolts Maintenance Engine Oil: 124,077 mi (Feb 06, 2021) Coolant: 123,200 mi2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
oceansize and heinzboehmer , these are absolutely spot on suggestions, I'm going to find out this week once we get under the car again to inspect!
Much appreciated! I'll update our findings here for others who may come across this.| 06 6 Speed Vert - JB on Cinnamon|Beisan|ACL RB's|ST Sway Bar|3.91|Bi-LED| TMS CSL Box|Megan headers|H.T.E Tune|Bryson Air Inlet|550 Injectors|OEM Section 1, 2, 3|200 Cell Cats|OEM SSK|Bilstein B12|712 yellow tag
Correct, CSB and exhaust hangers were changed, which most likely means: CSB needs to be adjusted or the driveshaft may be out of wack. From what I researched, could potentially be flex disc/giubo but it looked fine when we were underneath the car prior to changing the CSB.Originally posted by sapote View Post
So problem only happened after changing the CSB?| 06 6 Speed Vert - JB on Cinnamon|Beisan|ACL RB's|ST Sway Bar|3.91|Bi-LED| TMS CSL Box|Megan headers|H.T.E Tune|Bryson Air Inlet|550 Injectors|OEM Section 1, 2, 3|200 Cell Cats|OEM SSK|Bilstein B12|712 yellow tag
Update: Ended up being the driveshaft itself, the middle joint had gone bad. We used a driveshaft from another M3 to confirm.
Prior to this: Giubo looked good under inspection, we added more grease where the pumpkin and driveshaft meet (checked the seal as well) but issue still persisted.
Runs smooth now. Thanks everyone for your help and input!Last edited by siamkazi; 11-07-2024, 09:33 AM.| 06 6 Speed Vert - JB on Cinnamon|Beisan|ACL RB's|ST Sway Bar|3.91|Bi-LED| TMS CSL Box|Megan headers|H.T.E Tune|Bryson Air Inlet|550 Injectors|OEM Section 1, 2, 3|200 Cell Cats|OEM SSK|Bilstein B12|712 yellow tag
Yes the center joint, i think it's called a U-Joint, probably got bent when the CSB went bad and the driveshaft started banging against the chassisOriginally posted by sapote View Post
Next to CSB?| 06 6 Speed Vert - JB on Cinnamon|Beisan|ACL RB's|ST Sway Bar|3.91|Bi-LED| TMS CSL Box|Megan headers|H.T.E Tune|Bryson Air Inlet|550 Injectors|OEM Section 1, 2, 3|200 Cell Cats|OEM SSK|Bilstein B12|712 yellow tag
Letting the driveshaft hanging on one end without proper support would cause damaged to U-joint. People ignored this when working on it and ended up with more headache.Originally posted by siamkazi View Post
- Likes 2
That's a great point, hopefully this thread helps others in the future, it was definitely frustrating to find the root cause.Originally posted by sapote View Post
Letting the driveshaft hanging on one end without proper support would cause damaged to U-joint. People ignored this when working on it and ended up with more headache.| 06 6 Speed Vert - JB on Cinnamon|Beisan|ACL RB's|ST Sway Bar|3.91|Bi-LED| TMS CSL Box|Megan headers|H.T.E Tune|Bryson Air Inlet|550 Injectors|OEM Section 1, 2, 3|200 Cell Cats|OEM SSK|Bilstein B12|712 yellow tag
