Originally posted by heinzboehmer
SMG to 6MT Conversion
Originally posted by ejendow View Post
I haven't tried to hear a click when this issue is occurring but I feel that the wiring is done correctly, although its weird that this occurs on/off. This problem also leads me to believe its wiring related as well. Would it be the wiring thats connected to the EWS?
When the issue comes up, can you still hear the relay click when you push in the clutch? If not then that would point at a wiring issue or potentially a faulty switch.
yeah I’m unsure. It's just weird that unplugging/replugging the clutch switch fixes the problem.
The first thought that came to mind is you had an adjustable stop or it wasn't installed correctly and was keeping you from fully actuating the switch, but that doesn't seem to be the case then.
stock clutch stop
Originally posted by ejendow View PostI recently did the swap and since then I've had a no crank no start issue twice. Both times what allowed the car to start is unplugging the clutch switch and plugging it back in. Does anyone have any idea as to why this is happening? In between both cases, the car would start just fine. It is to note that I haven't removed the SMG ECU.
Originally posted by S3diment View PostFound a place that has a relatively low labor charge. For those that have done the swap recently, how much did parts cost you (not including the bellhousing)?
M is brown, non-M is black
Originally posted by terra View PostYes it needs to be 61319122700. BMW erroneously superseded it in the ETK to the non-M part. I hear if you can convince the parts guy to actually place the order for the old part number it will go through. 61319122701 (Euro M3/M5 switch) would work too, though it's unclear what's different about that one (I think it may not support the clutch interlock).
