Originally posted by FoxFivePointOh
SMG to 6MT Conversion
Well, carefully with dial indicator one can measure the dimension on the tranny input shaft shoulder relative to the box mating surface, and the dimension of the input bearing to the BH mating surface, then calculate the needed shim thickness to have proper bearing preload.
Could you copy and paste them to your post? This will be very helpful for all members.Originally posted by DiegoD View PostBy the way, I have the instructions to code everything I downloaded a few years back from the old forum. Let me know how to upload them because I have no idea lol.Last edited by sapote; 11-26-2020, 10:31 PM.
Do anyone know what is this Torx screw for? It was listed on the original post.Edited: It is located on top of the gear box but I don't know what's for. on this diagram: S6s420g inner gear shifting partsTorx Screw, micro-encapsulated M8x25 GetBMWParts 23317586637
Anybody have the McMaster Carr part numbers for the modified bell housing parts: large coil spring, small ball bearing which connected to the shifter arm?
I found the info:
McMaster-Carr: Bearing - 5972K91 Torsion spring - 9271K125Last edited by sapote; 11-26-2020, 02:47 PM.
I'm about to order the parts for converting a spare SMG to manual. Have a few questions for those who had done this.
1. Is it necessary to install the gear recognition sensor? Is it only needed for display the gears and cruise control functions? Why the SMG system doesn't need this sensor?
2. "Once the threads are cut as deep as they will go (the tap will stop when the end contacts the pressed bushing inside), clean out any excess grease and install your new shift detent, spring guide pin, and compression spring. Yes, these parts are different between the SMG and manual cars- do not try to reuse those from the SMG. Finally, screw in your new gear recognition sensor."
OP described the process but he didn't say to remove the original pressed busing before installing the new parts. Since the SMG used the spring and this pressed bushing, the word pressed makes me think this pushing is an interference fit then why it has the compressed spring on its? What is the function of the original spring/bushing on the SMG box?
Edited: I think I know its function: to have detent on the odd and even gears, i.e, 1,3,5,R vs 2,4,6. I will not use the gear position sensor and leave the stock SMG detent parts alone.Last edited by sapote; 11-26-2020, 10:00 PM.
good to know, I'll order it through themOriginally posted by wsybert View Post
I just bought one from eEuroparts. Had to call to make sure, but it got the 61319122700 part. Sales guy had to look it up to make sure it was what was on the shelf.
Anyone need a 35426876898 clutch switch? Make you a hell of a deal!
I can't remember exactly but I know that the connector was already under there, one of em was the reverse and only one other fit the GPS i just don't remember which one it wasOriginally posted by Mspir3d View PostWhere does the connector for the new gear position switch come from? It’s not the connector for the reverse switch correct?
I just bought one from eEuroparts. Had to call to make sure, but it got the 61319122700 part. Sales guy had to look it up to make sure it was what was on the shelf.Originally posted by ejendow View PostHas anyone had any luck purchasing the 61319122700 clutch switch recently? It seems like I can't find it anywhere and everyone just wants to send me the 35426876898 switch.
I do not think that is your issue.Originally posted by ejendow View Post
After reading more of this post carefully, I believe the problem might actually be the clutch switch. I accidentally purchased the #35426876898 switch instead of the #61319122700. Do you think this might be the issue? It's just weird to me that the 354 switch works "most" of the time haha.
61319122701 is the euro switch and does not have the clutch interlock circuit on it. It will work if you code it out which is relatively simple.Originally posted by m3nt0s View PostIs anyone aware of the difference between the clutch switch part numbers 61319122700 and 61319122701? There isn’t much to go on from realoem and the shop performing the swap is going with the PN ending in 701.
Seems silly but I noticed the gear position sensor harness is different than the smg one. Does the end need to be cut off and a new one soldered on to plug it in?
Hello guys! I’ve done the swap and the programming thanks to ECUWorks software and a tutorial on how to use NCS Expert I found on YouTube. The thing is, that when I fully push the clutch pedal my electrical system gets fishy... the blinkers won’t turn on, my steering controls won’t work, the headlights won’t start... but once I depress the pedal they all turn on. What could this be? I did recode the car to see if everything was OK and I get the same issue.
other thing is that the SMG rev light I coded with ECUWorks won’t work. Has anybody had this issue other issue after the swap?
