Originally posted by M3_ru33er
SMG to 6MT Conversion
Did you have to provide a vin? If so, I’m guessing your vin didn’t work since it didn’t originally come with the switch.
So i called my local BMW dealership and they are able to get it from Germany.
Their sales manager had to remove the supercession so they could order the xxxxx700 PN.
Sent from my SM-G998W using Tapatalk
I kept getting intermittent no start issues so what I did was code out the clutch to start feature and that resolved that issue. Not the best way to fix the issue but until I'm able to find the proper clutch switch that will have to do.Originally posted by M3_ru33er View PostDid this resolve your issue or do we need the brown clutch to make it work?
From what I remember the black clutch switch will work to start the car, however, cruise control will not work without the brown switch.Originally posted by M3_ru33er View PostDid this resolve your issue or do we need the brown clutch to make it work?
Planning on doing the swap and these seem impossible to come across. The link below says in stock. Hope it checks out.Originally posted by gheorghe View PostAnyone having any luck finding the brown clutch switch PN 61319122700?
I've struck out twice with sellers saying they have the part and even show the brown switch in the pictures but wind up sending the revised black switch PN 35426876898.
If anyone has an extra switch they're willing to sell please PM me.
Find Genuine BMW Clutch Pedal Ignition Lock Switch 61319122700 at discount prices in our extensive BMW auto parts catalog. AutohausAZ offers a large selection of Genuine BMW parts online. Fits BMW M3, Z4, M5. 35426876898 61310141210 61316905898 61316905900 61316912566 61319122702 61319231129
That looks normal to me.Originally posted by heinzboehmer View Post
Here's the slop on my car with an AS kit and almost all new detents in the transmission:
https://nam3forum.com/forums/forum/m...nsmission-slop
Here's the slop on my car with an AS kit and almost all new detents in the transmission:Originally posted by SQ13 View PostAlso, I have an AS 20% SSK installed.. if there is about 0.5” of play in the shifter both in neutral and in gear, is there anything that can be done to tighten it up? Or did the shop that machined the bellhousing screw it up permanently?
Anyone know the part number for the plug that connects to the OE illuminated shift knob? My swap isn’t complete without the illumination. :/
https://www.ecstuning.com/b-genuine-...r/25112282450/
Also, I have an AS 20% SSK installed.. if there is about 0.5” of play in the shifter both in neutral and in gear, is there anything that can be done to tighten it up? Or did the shop that machined the bellhousing screw it up permanently?Last edited by SQ13; 02-16-2021, 08:03 PM.
The previous owner did mine, I think it was done at around 106k, I have no idea why he did it. I bought the car with 111k on it. He didn't do it right though, car had a bunch of issues. I fixed all of them. Was a combination of not doing any of the required coding correctly and the absence of the cruise switch/clutch switch. He also had on a shifter I didn't like, but that's more personal preference.Originally posted by BubbaTree View Post
Just curious: what was your motivation to swap, how many miles on your car at the time, did you do the work yourself, and what do you calculate to be your all-in cost?
I like my SMG, but am considering this swap before the SMG system fails.
Thanks.
It didn't increase the resale value though, my car had so many problems I was able to buy it very cheap.
If you can change a clutch, you'd have no problem doing the conversation yourself, especially if you use OEM parts. There isn't really anything you need to modify to make it work.
Just curious: what was your motivation to swap, how many miles on your car at the time, did you do the work yourself, and what do you calculate to be your all-in cost?Originally posted by liam821 View Post
If you do it right it looks and drives exactly like a stock 6MT car. I promise you would never be able to tell my car was originally SMG unless you looked up the VIN. Shifts perfect and drives perfect.
Thanks.
Here's where I screwed up. I'd been collecting a box of parts for the swap. Things like Guibo, CSB, transmission mounts I had gotten a while back. I totally forgotten about the Revshift poly transmission mounts that I got a loooong time ago. Anyways, fast forward to when I dropped the car off. I literally handed my mechanic the few boxes that I had collected without remembering that I probably shouldn't do poly transmission mounts.
So for everyone out there that's considering this swap and NVH is a concern. Please do not do poly transmission mounts.
Fortunately it's only an hour long job and can be easily replaced.
have you read the DIY? short of doing a manual dash swap, it is virtually identical to a factory 6spd. mine drives fine, cruise control works, backup assist, even the mirror dip function.Originally posted by S3diment View PostHow does everyone’s car run after the conversion? I can’t help but think, that things are a little less refined after the conversion. Idk...
