Educate me on Carbon Airbox tunes
    Happy Tuesday everyone.
    I purchased a karbonius Airbox and while I’m waiting for delivery, I’m curious to know the the general consensus on tunes for these things. What options do we have and what gets the most performance out of Airbox. I’ve been trying to do some research on the web and haven’t found much info on this topic. To my understanding the Alpha-N tune, CSL DME, and kassell’s tune are what I’ve found. anyone have any preference or notable things to say that could help push me in the right direction? And do the air boxes require the csl map sensor in order to function or is that specific to the csl software ? Appreciate the help.
    • 2006 AW/IR Manual
    • Karbonius Race / Alpha- N
    • Supersprint
    • KW V3
    • 996 Brembo
    • ZCP / PSS
    Alpha-n tunes don't require a MAP sensor. Some people really like them, some don't. Supposedly, alpha-n tunes have some drivability issues, but it seems like it depends on how well the tune is made. Personally I added a MAP sensor. There are canned alpha-n tunes available (I think Evolve offers one?), but these usually require dialing in on a dyno afterwards.
    The stock CSL tune will work with an airbox and MAP sensor, as long as it's modified to suit the rest of the car (manual, stock cams, etc). However, running this tune requires an HP DME (found on facelift cars) and you will not get as much power out of the airbox when compared to a dyno tune. This is the route I went with, as I decided to wait until I get cams and headers before getting a dyno tune.
      I tune both setups, both Alpha N and a MAP sensor based management will work just fine(just like stock) if tuned right, both will drive like crap on a crappy tune. On my own car , I run alpha N, have been doing so for the past 4 years. Zero issues.
      385.7whp 288.8 wtq :
      -CSL airbox ( custom)
      -280 272 Cat cams
      -Custom SSV2, modified for a bigger collector
      -Custom Section 1 2 and 3: oversized to 2.5 inch and en E9xM Xpipe
      -TMS pullies
      -Electric Fan
      -HTE performance Tune :P
      PM for performance Tunes
      IG: https://www.instagram.com/hte_performance_tuning/
        I've been very happy with the tuning work and advice Randy Mueller at EPIC (https://epicmotorsports.com/) has done on my car.
        Feff
        MVP Track Time
          Out of curiosity, anyone have any experience running the CSL tune with a CSL box, but US spec headers? From what I can tell almost everyone who upgrades to a CSL box and software usually already has already ditched the US catted headers. Of course, euro headers will always be better, but the CSL tune specifically expects euro headers. I won't be upgrading my headers for at least a couple months.. I'm wondering if running the CSL tune with US headers will cause any drivability issues other than not making quite as much power as it would with euros?
            I've got a CSL box with stock cams and stock US headers on a CSL tune. No drivability issues. I do want to eventually get cams, headers, and a dyno tune, but in the mean time, I'll stick with this setup as I've had no issues.
              For the karbonius guys - did you have to change out the boots on the box? I remember seeing something a while back that you need to purchase a smaller size or source them of an pre 2004 m3. The boots are like $40 a pop or buy an old Airbox for 80? Also did you guys swap out to silicone radiator hoses.
              • 2006 AW/IR Manual
              • Supersprint
              • KW V3
              • 996 Brembo
              • ZCP / PSS
                I THINK if your car was made after 10/2004 you need the smaller boots. Mine was made 06/2004 and I did not need new boots.
                Also, use factory clamps, yes they require the use of two separate tools, but so worth it imo.
                  FWIW as soon as my Turner shows up, I am going to be scheduling some time on my local Dyno to have Hassan tune mine!
                    To my understanding that is correct. Do you by chance know the size of the boots or part number?
                    • 2006 AW/IR Manual
                    • Supersprint
                    • KW V3
                    • 996 Brembo
                    • ZCP / PSS
                      Yeah you need the boots from 10/2004 or earlier. P/N is 11617830265. At $40 a pop I think you'd be insane to buy a set new. They're robust and you can pull them off a used intake. Or, even easier, Turner sells their own set for $100 total: https://www.turnermotorsport.com/p-5...t-with-clamps/ ... not OE but I don't think it matters in this instance.
                        Clamps P/N? Were there different variations of the clamp?
                        Current:
                          https://www.ecstuning.com/b-genuine-...h/11617830306/
                          https://www.ecstuning.com/b-genuine-...h/11617831745/
                          Those are what you'll need and there are not different variations to my knowledge. You will also need these tools, do it, don't use hose clamps.
                          https://www.amazon.com/gp/aw/d/B0002...b_b_asin_title
                          https://www.amazon.com/Lisle-30800-B...D9V1P9GJ6F69AC
                            Just to add to this…I have a Turner CSL Intake, Megan headers, and using an OE IAT sensor in the plenum with an Epic Tune. After dyno tuning, there are no noticeable driveability concerns and the car rips.
                            Just plan on the dyno tune as part of the project.
                              Question for the CSL intake crowd. I want the easiest CSL intake setup so that I can uninstall and reinstall the box every two years. This is due to CA smog reasons. Would that just be to get the CSL intake and the get an OTS alpha N tune? I also currently have a dinan stage 1 tune on my car and bought it that way. Would that be considered my base tune when flashing the new alpha N tune?
