So I've got an OE CSL trunk on order as well as all the neccessary bits, or so I think. Is there any go to DIY you guys can link me to? Also, will the trunk handle simply swap over? I have yet to see a new/different trunk handle mentioned on any of the CSL trunk parts lists that I have come across thus far. My car was manufactured 06/2004, thanks for any help!
CSL trunk install DIY?
InstagramTags: None
Wow...duh. Thanks for the link.Originally posted by Slideways View PostThe OE CSL bootlid does not utilize the trunk handle....2004 Silbergrau Metallic 6MT
That DIY doesn't go too far into detail about the wiring. For the wiring portion, it seems similar to this guide:Originally posted by Slideways View PostThe OE CSL bootlid does not utilize the trunk handle.
It looks like Daytona Violet's Vorsteiner CSL Bootlid DIY still exists. I attached the PDF.
Very niceOriginally posted by BMWahba View Post2004 Silbergrau Metallic 6MT
It looks like you may have already gotten what you need, but this was the diagram I made when I wired my lights, if it helps at all..
CSL Trunk Wiring Diagram.pdf
-Brandon
2005 M3 BMW Individual Sterling Gray / Imola Red 6MT
That is awesome, thank you!Originally posted by Smitsky089 View PostIt looks like you may have already gotten what you need, but this was the diagram I made when I wired my lights, if it helps at all..
[ATTACH]n29248[/ATTACH]
it's only 3 wires. how much more detail does it needOriginally posted by BMWahba View Post
The oem connector which goes to the trunk release and license plate lights has the following 3 wire colors brown, grey/brown stripe and grey/yellow stripe). Splice in the brown and grey/brown for each of the new registration plate light: 63 26 7 165 646. The grey/yellow wire is for oem trunk release which will no longer be used.
Oh what do you knowOriginally posted by Daytonaviolet View Post
The oem connector which goes to the trunk release and license plate lights has the following 3 wire colors brown, grey/brown stripe and grey/yellow stripe). Splice in the brown and grey/brown for each of the new registration plate light: 63 26 7 165 646. The grey/yellow wire is for oem trunk release which will no longer be used.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
