Upgraded injectors question
    Hey Guys,
    So I've been searching the forums and it seems to come down to the Bosh EV14 and the Porsche TT, for a FBO NA build (NO PORTED HEAD).
    For reference:
    CSL ECU
    288/280 cams
    Karbonius CF airbox
    SS V1
    SS HFC Sec 1
    SS Sec 2 unresonated 2.5 inch
    Scorza exhaust
    Turner bullies
    Efan
    I'm looking for something that still fits with the oem fuel rail. Are these the best options and which one?
    Thanks!!
    Better to contact your tuner. Hassan HTE recommended https://polmaxracing.com/index.php/p...280158117-s54/
      EthanolTurbo duracellttu have both gone with those and have documented their route at length. I have the same injectors and radium rail and will also follow suit and drop my findings as well.
        I installed those Bosch EV14 injectors on a recently rebuilt S54, I probably wouldn't do them again. Too much headaches/costs with needing to buy a fuel rail, plumbing kit, spacers, and tuning them accordingly.
          Plumbing kit?
          Also, is a Radium fuel rail necessary?
          EthanolTurbo
          duracellttu
            Not typically. New lines would be required if you wanted to move to an aftermarket rail, there are lots of ways to do it but 6an lines / fittings would be suitable for an NA car.
            Definitely contact your tuner and ask them about injector sizing based on target power level and brand of injector. With our standalone we needed to have injector deadtime data from the manufacturer to get them working properly.
              Plumbing kit?
              EthanolTurbo
              duracellttu
              Check out my post #23 in this thread.
              Bosch style injectors leaking
              My car has been in the shop going on close to two months now. I had them put on a smaller pulley on my supercharger, and swap my injectors and fuel pump for bigger units. ID1050x to be exact. They haven't been able to get my injectors to seal properly yet. At first, they weren't sealing at all. So they sent the adapters to a
              Short answer is no, it's not required but makes the install easier. If you choose to keep the stock fuel rail you will need to modify the mounting holes and raise the hardline fuel source line from the filter/FPR.
              I didn't want to irreversibly modify the stock fuel rail.
              2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 288/280 Schrick Cams+DLC Followers | Lang Head | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 400/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | Turbo Toys V2 Hub | WPC Rod Bearings
