Replaced front rotors and pads yesterday. As I was compressing the piston back in, I had the bleeder screw open to avoid sending anything back up into the ABS system. This was out of an abundance of caution. I've never done this job before. I am pretty sure I took my clamp off the piston before I tightened the bleed screw. I am thinking a little air got in b/c my pedal is going about half way down before the pad grabs.
Knowing I only did front, do I need to bleed all four calipers? What about the clutch and ABS / DSC bleed procedure? Just want to make sure I'm not messing anything up.
Thanks all!
Thanks all!
