I thought this would go away after my clutch broke in a bit. I'm at about 830 miles on the engine and OEM LuK clutch, and it's still here. What is this noise around 4k at the end of this vid?
New engine, new clutch, what's this noise?
Flywheel came with the clutch I am pretty sure. The noise is not always at the same RPM. It's most pronounced right in that range. But it also doesn't happen as much if I'm on the throttle pretty aggressively. It's only when I'm sort of about to ease off, or just slowly approaching that 4k range.Originally posted by Halftim3 View PostOem flywheel? Loose heat shields? Is the noise at the same rpm in every gear?
Like a heat shield rubbing against the driveshaft or something. That vibration doesn't sound random...Originally posted by Nate047 View PostTo me that sounds like a heat shield or something moving around. I would put the car on a lift and "drive" it in gear, see if the sound occurs still, or if it only occurs when the car is on the ground actually moving around.
