Need help diagnosing/prioritizing what to check:
So I've driven this car for around 2K miles now. Intermittently and now seems more often than not, when I release the clutch reverse gear, 1st, 2nd, and sometimes 3rd pops out. This happens when it's cold or warm. Sometimes I could drive it for a few weeks without an issue. When I engage a gear, there are instances where I know it will pop out. It feels like the gear is not fully engaged as if the travel distance is not as far as it should be. It doesn't pop out when driving and there is not gear grinding that I notice unless you try to force it.
I am planning to change the clutch and with it, refresh shifter linkage and detent springs.
I am hoping this will solve it other than having to replace the transmission. I've watched a few Getrag rebuild videos, but don't know enough about the cause.
Appreciate any guidance/help.
