STOPTECH ST60 & ST40 Parts Info
    Hey All,
    I am creating this thread for all of us who have STOPTECH brake systems and to have the info and suggestions from community members in one place.
    I have the Black Stoptech ST60 355MM Front & ST40 355M Rear Big Brake Kit on my E46 M3 and have been having a tough time sourcing some parts and getting in touch directly with STOPTECH. I used to have a dealer account with them and all my POCs are gone and I cant log in and cant contact any one so here are the parts and info I am looking for without having to take my brakes apart:
    Boots and Seals Kit:
    Anyone know the Sizes for the pistons for ST60 and ST40 E46 M3 application specific, please post them up.
    E46 M3 ST60 Piston Size for boot and seals kit
    E46 M3 ST40 Piston Size for boot and seals kit
    Brake Pads:
    ST60 Street Pads recommendation and if they can support the wear sensor that'll be a plus
    ​ST40 Street Pads recommendation and if they can support the wear sensor that'll be a plus
    ST60 and ST40 Rotors:
    As far as Rotors I have found two options and am leaning towards the Girodisc due to having direct contact with them and they being a breeze to deal with:
    https://www.zeckhausen.com/catalog/index.php?cPath=24_8689
    https://girodisc.com/355x32mm-replacement-rotor-rings-52mm-annulus/
    Another choice is Stoptech's Aero rotors
    ST60 and ST40 Brake Lines:
    For ST60 Front: https://www.zeckhausen.com/catalog/p...roducts_id=433
    For ST40 Rear https://www.zeckhausen.com/catalog/p...oducts_id=1059
    STOPTECH Logo for calipers:
    ST60 and ST40 LOGO stencil, Any suggestions where to source these from? Will definitely need these before i do anything at all. Found these:
    https://www.projectb5.com/product/project-b5-stoptech-caliper-decals
    https://www.ebay.com/itm/144513720148?var=444244495460
    Zeckhausen has a great section for STOPTECH parts: https://www.zeckhausen.com/catalog/index.php?cPath=24&osCsid=df7jt8588q9nmv8cjhli1amk 67
    Appreciate all the help guys as shop is full so If i have the above correct parts in hand in advance I can just take the car in and have everything removed and run the calipers over for powder coating.
    Any suggestions on what Caliper color might be OE+ on a JB M3 Coupe with Silver BBS LMs?
    ST60 Front ST40 Rear “Trophy” kit piston sizes:
    ST60 Front:
    2x 36mm
    2x 34mm
    2x 28mm
    ST40 Rear:
    4x 28mm
    A front-only kit will have different piston sizes than above.
    For example my old (Gen4 ST40) front only kit had:
    2x 44mm
    2x 38mm
      ST60 Front:
      2x 36mm
      2x 34mm
      2x 28mm
      ST40 Rear:
      4x 28mm
      2x 44mm
      2x 38mm
      Thanks for that info. I am guessing i am going to have to remove the calipers and measure them as mine are the Non Trophy versions.
        Weissgold is nice and would look subtle behind the LM's.
        I've got a set of non trophy in the garage I should be able to measure the pistons for you tonight.
          This is how I measured:
            That color sounds good! I'll go check the samples one of these days and post up pics.
            Thanks that would be great.
              I'll figure out a way to measure them if no one here has the info as I can't disassemble them and wait two weeks for parts to arrive and then another week to get the PC done etc.
                Email David Zeckhausen. I think its [email protected]. He might be able to ID the piston sizes without measuring them.
                  Good looking out, I would have just measured the tapered portion.
                    In the off-chance that your boots are still intact, it will have the piston size on them:
                      Oh perfect! Yea they are / should be intact. Thanks.
                        I wish i had dust boots…
                          Ive got dust boots should you need them. I haven't rebuilt stoptech calipers in a long time but they use the brembo dust boots..
                          Mike
                          OPS
                          High Temp Caliper Rebuild Kits For Brembo Calipers; Caliper Pistons
                          www.ohioperformancesolutions.com
                          2007 C4S F77 Aerokit / 2004 E46 M3 / 2018 M3 comp​
                            Zeckhausen is a phenomenal source regarding stoptech, especially since they've become less than stellar to deal with directly and parts supply has become extremely difficult.
                            For replacement seals and boots, i'd recommend looking at Girodisc, they also supply replacement rings for stoptech kits which are fantastic.
                            '02 E46 M3 - The high mileage street car
                            '05 E46 m3 - The neglected race car
                            '02 S2000 - The side chick
                            YouTube & Instagram for track stuff!
                              Mike
                              OPS
                              Mike,
                              Will have to contact you once i know the sizes for the boots needed for both ST60and ST40 E46 M3 applications. Thank you.
